[MPICH] MPICH error in MPI::Lookup_name (MPI_Lookup_Name)
    Rusty Lusk
    lusk at mcs.anl.gov
    Wed Feb  1 13:18:15 CST 2006
Subject: [MPICH] MPICH error in MPI::Lookup_name (MPI_Lookup_Name)
Date: Tue, 24 Jan 2006 16:16:57 -0500
> I found that the implementation of MPI::Lookup_name scribbles outside
> its buffer.  The MPI spec says that the third argument is a buffer of
> MPI_MAX_PORT_NAME characters, but the MPICH implementation expects the
> buffer to be 1024 characters: in PMI_Lookup_name( const char
> service_name[], char port[] ), the call is to PMIU_getval( "port", port,
> PMIU_MAXLINE ), where PMIU_MAXLINE = 1024.
> In mpi.h, MPI_MAX_PORT_NAME is 256.
> thanks,
> /jr
Thanks for your report.  This has been fixed for the next release.  In
the meantime, here is a patch you can use.  The file simple_pmi.c is in
mpich2/src/pmi/simple .
Rusty Lusk
*** simple_pmi.c	20 Jan 2006 19:35:59 -0000	1.85
--- simple_pmi.c	1 Feb 2006 19:10:18 -0000
*** 49,54 ****
--- 49,55 ----
  #include "pmi.h"
  #include "simple_pmiutil.h"
+ #include "mpi.h"		/* to get MPI_MAX_PORT_NAME */
     These are global variable used *ONLY* in this file, and are hence
*** 683,689 ****
  	        return( PMI_FAIL );
! 	    PMIU_getval( "port", port, PMIU_MAXLINE );
      else
--- 684,690 ----
  	        return( PMI_FAIL );
! 	    PMIU_getval( "port", port, MPI_MAX_PORT_NAME );
      else
