[MPICH] MPICH2 hangs on diskless SuSE 10.2 based cluster
Shaun Q shaun at c-think.com
Thu Dec 21 17:16:37 CST 2006
Rusty --
This I did. I can start mpd on one machine, manually connect it to another
machine, do a ringtest, do a trace....  Still the same problem.
I am running the 1.0.5 release also, FYI.
Any ideas?
Thanks!
Shaun
>I recommend that you follow the steps in the User's Guide starting with
>the use of mpdcheck to make sure both machines are properly configured
and
>can communicate with one another, and start the mpd's on these two
>machines "by hand" instead of going immediately to the more scalable but
>less informative mpdboot.
>Regards,
>Rusty
On Dec 20, 2006, at 6:33 AMDecember, Shaun Qualheim wrote:
     Hey everyone...
     I'm trying to figure out why I'm having an issue with running a job on
multiple machines here.
     It worked fine with a 32-bit SuSE 9.3 based setup.
     I started it up with a 64-bit base distro and kernel...
     I can start up the process with:
     mpd &; mpiexec -n 2 process &
     and it starts with no issues...
     When I try doing that with 2 machines though...
     mpdboot -n 2 &; mpiexec -n 2 process &
     It hangs for about 5 minutes and then starts up.
     After it starts up and runs to completion, I can issue the same
command again and it starts up right away.
     Any ideas of where to start here or what might be causing this issue?
     Thanks!
     Shaun
