[MPICH] exception hangs app
Tom Hilinski tom.hilinski at comcast.net
Thu Aug 31 07:48:16 CDT 2006
Followup to my example:
I discovered that in LogsMessages, moving the MPI code out of the
constructor causes the example to run ok. The altered code looks like this:
class LogsMessages
  public:
    LogsMessages ()
    void Activate ()
        cout << "LogsMessages: Probe/Recv" << endl;
        MPI::Status status;
        MPI::COMM_WORLD.Probe ( MPI_ANY_SOURCE, MPI_ANY_TAG, status );
        int const count = status.Get_count (MPI::CHAR);
        char * buffer = new char [count + 1];
        MPI::COMM_WORLD.Recv (
                buffer, count, MPI::CHAR,
                status.Get_source(), status.Get_tag() );
        std::string msg (buffer, buffer + count);
        cout << "LogsMessages msg: " << msg << endl;
        delete [] buffer;
class Task
  public:
    Task (int const rank)
      if ( rank == 0 )
        ThrowException (rank);
      else if ( rank == 1 )
        // following works
        LogsMessages msgs;
        msgs.Activate ();
        // following hangs:
        // LogsMessages msgs ();
      else
        DoTask (rank);
Any ideas on why the constructor must complete before the blocking
messaging works?
BTW, same result on g++ 3.4.4 and 4.0.1, and cygwin and linux, same
version of mpich.
...Tom
William Gropp wrote:
> Can you send a short program that illustrates the problem?  What you
> describe should work.
> Bill
> On Aug 30, 2006, at 4:00 PM, Tom Hilinski wrote:
>> For mpi/c++ gurus: I have an app that has classes can throw an
>> exception, specifically std::runtime_error. main() has a try-catch
>> for these as well as MPI::Exception. When a process (rank == 0)
>> throws an exception, the process seems to go off into space - I can't
>> trace it in a debugger, and the exception is not caught by the catch
>> (which immediately writes e.what() to cout).  I can kill it with
>> mpdkilljob.
>> I've reproduced this behavior on both suse linux 10.0/x86_64 and
>> Win2K/cygwin. MPICH version is mpich2-1.0.4p1, which I've built with
>> debugging enabled (--enable-debuginfo --enable-g=dbg,handle) and no
>> threads.
>> Any suggestions you have would be great.
Tom Hilinski
e-mail    Personal: Tom.Hilinski at comcast.net
          CSU:      Tom.Hilinski at ColoState.edu
