[MPICH] exception hangs app
William Gropp
gropp at mcs.anl.gov
Wed Aug 30 16:34:45 CDT 2006
Can you send a short program that illustrates the problem? What you
describe should work.
Bill
On Aug 30, 2006, at 4:00 PM, Tom Hilinski wrote:
> For mpi/c++ gurus: I have an app that has classes can throw an
> exception, specifically std::runtime_error. main() has a try-catch
> for these as well as MPI::Exception. When a process (rank == 0)
> throws an exception, the process seems to go off into space - I
> can't trace it in a debugger, and the exception is not caught by
> the catch (which immediately writes e.what() to cout). I can kill
> it with mpdkilljob.
> I've reproduced this behavior on both suse linux 10.0/x86_64 and
> Win2K/cygwin. MPICH version is mpich2-1.0.4p1, which I've built
> with debugging enabled (--enable-debuginfo --enable-g=dbg,handle)
> and no threads.
> Any suggestions you have would be great.
