[MPICH] mpich2 1.0.3, 32 bits build problem on Redhat ES4, amd64
chong tan
chong_guan_tan at yahoo.com
Thu Aug 17 00:19:27 CDT 2006
yes.
tan
Rajeev Thakur <thakur at mcs.anl.gov> wrote:
With the --enable-fast build, do the tests in the MPICH2 test directory
compile?
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of chong tan
> Sent: Wednesday, August 16, 2006 7:22 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] mpich2 1.0.3, 32 bits build problem on
> Redhat ES4, amd64
> using gcc 4.0.2. The 64bits build works fine.
> I am using 2 csh files to do the build, first is a
> debug build, which works OK :
> #!/bin/csh -f
> setenv CFLAGS "-g -m32"
> setenv CC gcc
> setenv CXX g++
> setenv CXXFLAGS "-g -m32"
> ./configure -prefix=/usr/local/mpich --enable-cxx
> --disable-f77 --disable-f90
> make
> make install
> The second, which is the optimized , with no checking:
> #!/bin/csh -f
> setenv CFLAGS "-O2 -m32"
> setenv CC gcc
> setenv CXX g++
> setenv CXXFLAGS "-O2 -m32"
> ./configure -prefix=/usr/local/mpich_opt --enable-fast
> --enable-cxx --disable-f77 --disabl
> e-f90
> make
> make install
> when the library is, libmpichcxx.a, is linked with an
> 32 bit application (co,piled -m32), the one built with
> '--enable-fast' causes :
> -/usr/bin/ld: skipping incompatible
> /usr/local/mpich_opt/lib/libmpichcxx.a when searching
> f
> or -lmpichcxx
> /usr/bin/ld: cannot find -lmpichcxx
> collect2: ld returned 1 exit status
> appearantly the library is built 64bit even with
> "-m32".
> the difference between the 2 scripts are '-g' and
> '-O2', and this '--enable-fast'.
> Any suggestion ?
> thanks
> tan
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
Get your email and more, right on the new Yahoo.com
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060816/0358e807/attachment.htm>
