[MPICH] mpich without shared home directories
H. Sami Sozuer
hss at photon.iyte.edu.tr
Mon Apr 24 07:35:19 CDT 2006
Hi Goncalo,
We're running mpich2 on individual machines that have separate home
directories.
It's even possible to run mpi jobs across different platforms such as
Windows+cygwin and Linux.
All you need is to have the same username on all the nodes. The user
needs to be able
to ssh to all the machines without a password from the machine where
mpdboot is issued
and then the binary needs to be copied to the same location i.e.
/home/me/myprog on each node.
Then you simply issue a command like mpiexec -n 5 /home/me/myprog after
running mpdboot.
However on Windows and Linux machines the program needs to be compiled
separately
and on Windows the executable would be named myprog.exe
You can also use mpich on either the Windows+cygwin or Linux systems but
without
mixing the platforms.
Sami
Goncalo Borges wrote:
> Hi there,
> I was hopping if someone could answer to the following question:
> - Is it possible to run mpich2 jobs in a cluster where the users do not
> share their homes across the different execution nodes?
> If this is possible, I would like to know how can I implement the
> procedure. What references should I look?
> Thanks in advance
> Cheers
> Goncalo
