[MPICH] MPI_GET_ADDRESS
Kenneth Rempe Kenneth.Rempe at studsvikscandpower.com
Sun Apr 23 14:41:49 CDT 2006
Hi Bill,
The output from configure on both AIX and Linux is "checking size of
void *... 4."
So, it likes there is a problem with the sign fortran integers.
Ken
William Gropp wrote:
> At 01:51 PM 4/21/2006, Kenneth Rempe wrote:
>> Bill,
>> Okay, what am I looking for in the configure output. Is there a why
>> to override what configure is setting?
>> Also, is this a problem because in C++ you can use an unsigned int
>> for addresses up to 4GB but in fortran it is a signed integer
>> which only can go up to 2GB?
> The first thing to look for is the size of void *.  The line should
> look like
> checking size of void *...8
> If the size if 4, then you have 32 bit pointers.  There may then be a
> problem, as you suspect, with the signed integer in Fortran.
> Bill
>> Thanks
>> Ken
>>> At 08:02 AM 4/21/2006, Kenneth Rempe wrote:
>>>> On both the Linux and IBM the value of MPI_ADDRESS_KIND is set to a
>>>> 4 byte integer.
>>> That's the problem.  If the sizeof a pointer is 8 bytes, then
>>> MPI_ADDRESS_KIND should be an 8 byte integer. What is the output of
>>> configure for MPICH2?  Note that MPICH2 must be configured with
>>> compatible compiler options for systems that support multiple
>>> datatype sizes (such as 32 and 64bit pointers).
>>> Bill
>>>> Linux   Red Hat Enterprise 3
>>>>           Lahey Fortran Compiler version 6.2c
>>>>           gcc version 3.2.3
>>>> IBM    Aix 5.2
>>>>           xlf compiler version 8.1
>>>>           xlc compiler version 6.0
>>>> *** NOTE: soa.com will no longer be used after February 1, 2006,
>>>> please change your address book ***
>>>> Kenneth R. Rempe                * email:
>>>> kenneth.rempe at studsvikscandpower.com
>>>> Studsvik Scandpower, Inc.       * 504 Shoup Avenue Suite #201     *
>>>> voice:  208-522-4630
>>>> Idaho Falls, ID USA 83402-3502  * fax:    208-522-1187
>>> William Gropp
>>> http://www.mcs.anl.gov/~gropp
>> voice:  208-522-4630
> William Gropp
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060423/9d5ab955/attachment.vcf>
