[MPICH] mpdboot error : fail to ping
Ralph M. Butler
rbutler at mtsu.edu
Sun Apr 9 18:55:10 CDT 2006
Yes this might be a bit difficult to pick up on.
The install guide discusses an assumption of shared file
systems, e.g. via NFS, or the need to copy files.
I can duplicate this problem only by having different secretwords
on 2 machines. Perhaps you can simply copy one file to the other
to verify that the 2 secretwords are identical.
> Date: Mon, 10 Apr 2006 05:47:35 +0700
> From: Misora Itsumo <mitsuru.adachi at gmail.com>
> To: Ralph Butler <rbutler at mtsu.edu>
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] mpdboot error : fail to ping
> ah , because i dont know whether secrets in both node must be similar or not
> , i have already tried to make it the same , but it produced the same error.
> Thanks,
> Tiep.
> On 4/10/06, Misora Itsumo <mitsuru.adachi at gmail.com> wrote:
>> yes , as ralph said , both my secretwords in two nodes are integer.
>> i changed my secret and it didn't inform last error anymore,
>> but sadly , it produced new error
>> in node hewonty i did
>> [hewonty at hewonty doc]$ mpd &
>> [1] 4293
>> [hewonty at hewonty doc]$ mpdtrace -l
>> hewonty.homelinux.org_32800 (192.168.2.2)
>> [hewonty at hewonty doc]$ hewonty.homelinux.org_32800(handle_rhs_challenge_response 788): INVALID response in rhs response
>> msg=:{'ifhn': '192.168.2.3', 'cmd': 'challenge_response', 'port': 32774,
>> 'response': 'X\xc5\x8f\x9ccfS\x8e\xaa\r\xde6$Y+\x81'}:
>> in node vm1
>> [hewonty at vm1 ~]$ mpd -h hewonty -p 32800
>> vm1_32774 (connect_lhs 635): NOT OK to enter ring; one likely cause:
>> mismatched secretwords
>> vm1_32774 (enter_ring 566): lhs connect failed
>> vm1_32774 (run 233): failed to enter ring
>> ah for testing , my secret for hewonty is asdfghjkl1 , for vm1 is
>> qwertyuiop1
>> Thanks,
>> Tiep.
>> On 4/9/06, Ralph Butler <rbutler at mtsu.edu> wrote:
>>> This seems to be a new bug. I do not want to ask your secretword,
>>> but will guess that it is an integer. If so,
>>> please make it a non-integer. It's OK to have digits in there, but
>>> not to have the secretword be all digits.
>>> Let me know if this fixes the problem and I will fix it in mpd for
>>> the next release.
>>> Thanks.
>>> --ralph
>>> On Apr 8, 2006, at 1:31 PM, Misora Itsumo wrote:
>>>> i have already tried mpdcheck .
>>>> [hewonty at hewonty ~]$ mpdcheck -s
>>>> server listening at INADDR_ANY on: hewonty 32775
>>>> server has conn on <socket._socketobject object at 0xb7f7838c> from
>>>> (' 192.168.2.3', 56366)
>>>> server successfully recvd msg from client: hello_from_client_to_server
>>>> [hewonty at vm1 ~]$ mpdcheck -c hewonty 32775
>>>> client successfully recvd ack from server: ack_from_server_to_client
>>>> [hewonty at vm1 ~]$ mpdcheck -s
>>>> server listening at INADDR_ANY on: vm1 32771
>>>> server has conn on <socket._socketobject object at 0xb7f5920c> from
>>>> ('192.168.2.2 ', 33169)
>>>> [hewonty at hewonty ~]$ mpdcheck -c vm1 32771
>>>> The next thing , i tried to run mpd by hand , but got error like
>>>> the last post.
>>>> [hewonty at vm1 ~]$ mpd &
>>>> [1] 2056
>>>> [hewonty at vm1 ~]$ mpdtrace -l
>>>> vm1_32772 ( 192.168.2.3)
>>>> [hewonty at hewonty ~]$ mpd -h vm1 -p 32772
>>>> hewonty_32846: mpd_uncaught_except_tb handling:
>>>> exceptions.TypeError: sequence item 0: expected string, int found
>>>> /usr/local/mpich2/bin/mpdlib.py 627 connect_lhs
>>>> response = md5new(''.join([self.secretword,msg
>>>> ['randnum']])).digest()
>>>> /usr/local/mpich2/bin/mpdlib.py 564 enter_ring
>>>> numTries=ntries)
>>>> /usr/local/mpich2/bin/mpd 231 run
>>>> rhsHandler=self.handle_rhs_input)
>>>> /usr/local/mpich2/bin/mpd 1344 ?
>>>> mpd.run()
>>>> If i run mpd in hewonty first i got :
>>>> [hewonty at hewonty ~]$ mpd &
>>>> [1] 4051
>>>> [hewonty at hewonty ~]$ mpdtrace -l
>>>> hewonty_32781 (192.168.2.2)
>>>> [hewonty at vm1 ~]$mpd -h hewonty -p 32781
>>>> vm1_32776 (connect_lhs 621): invalid challenge from hewonty 32781: {}
>>>> vm1_32776 (enter_ring 566): lhs connect failed
>>>> vm1_32776 (run 233): failed to enter ring
>>>> and in hewonty i get the error
>>>> hewonty.homelinux.org_32781: mpd_uncaught_except_tb handling:
>>>> /usr/local/mpich2/bin/mpdlib.py 733
>>>> handle_ring_listener_connection
>>>> newsock.correctChallengeResponse = \
>>>> /usr/local/mpich2/bin/mpdlib.py 488 handle_active_streams
>>>> handler(stream,*args)
>>>> /usr/local/mpich2/bin/mpd 266 runmainloop
>>>> rv = self.streamHandler.handle_active_streams (timeout=8.0)
>>>> /usr/local/mpich2/bin/mpd 240 run
>>>> self.runmainloop()
>>>> mpd.run()
>>>> [1]+ Exit 1 mpd
>>>> Regards,
>>>> Tiep.
>>>> On 4/8/06, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>>>> Try running the mpdcheck troubleshooting utility as described in
>>>> the installer's guide.
>>>> Rajeev
>>>> From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-
>>>> discuss at mcs.anl.gov] On Behalf Of Misora Itsumo
>>>> Sent: Friday, April 07, 2006 5:59 PM
>>>> To: mpich-discuss at mcs.anl.gov
>>>> Subject: [MPICH] mpdboot error : fail to ping
>>>> Hi
>>>> i'm new to MPICH2 and i just installed mpich2 , but i can't make it
>>>> run on a set of machines.
>>>> i run mpich2 on 2 nodes , hostnames are hewonty and vm1.
>>>> Here are some info
>>>> [hewonty at hewonty ~]$ cat mpd.hosts
>>>> hewonty
>>>> vm1
>>>> [hewonty at hewonty ~]$ cat /etc/hosts
>>>> 127.0.0.1 localhost.localdomain localhost
>>>> 192.168.2.2 hewonty.homelinux.org hewonty.vmnet1.org
>>>> hewonty
>>>> 192.168.2.3 vm1.hewonty.homelinux.org vm1
>>>> 192.168.2.2 svn_server
>>>> [hewonty at hewonty ~]$ mpdboot -n 2 -f mpd.hosts
>>>> mpdboot_hewonty (handle_mpd_output 359): failed to ping mpd on
>>>> hewonty; recvd output={}
>>>> i can ssh to hewonty or vm1.
>>>> I tried to run mannually by mpd and here are what i got
>>>> [1] 2056
>>>> vm1_32772 (192.168.2.3)
>>>> response = md5new(''.join([ self.secretword,msg
>>>> numTries=ntries)
>>>> rhsHandler= self.handle_rhs_input)
>>>> mpd.run()
>>>> Thanks in advance.
>>>> Tiep
