[MPICH] MPICH2 startup w/ PBS
Jeffrey B. Layton
laytonjb at charter.net
Tue Apr 4 13:41:06 CDT 2006
The machine I'm using has multiple ethernet interfaces. By using
the -machinefile argument I can control which interface I run on.
> Is there any particular reason you use the -machinefile argument to
> mpiexec, rather than just let the mpd's start the processes in
> round-robin fashion?
> From: "Jeffrey B. Layton" <laytonjb at charter.net>
> Subject: Re: [MPICH] MPICH2 startup w/ PBS
> Date: Tue, 04 Apr 2006 12:10:23 -0400
>> Darius Buntinas wrote:
>>> What's "screaming"? mpdboot or mpiexec?
>> I'm pretty sure it's mpdboot.
>> I'll try the method below to see what happens. I'm also going
>> to try Pete's mpiexec based on some recommendations to see
>> if that reduces the pain.
>> Thanks!
>> Jeff
>>> Try:
>>> mpdboot -n ${NP} -f ${PBS_NODEFILE}
>>> mpiexec -n ${NP} ./${EXE}
>>> You don't need a machinefile with mpiexec unless you want to execute
>>> on a subset of the nodes in your mpd ring, or you want control of the
>>> process-to-node mapping.
>>> I think that mpdboot should only start one mpd oer node, even if the
>>> node is specified more than one time in the file (you really only ever
>>> need one mpd per node). If mpdboot is having trouble because you're
>>> asking for ${NP} mpds but there are only ${NP}/2 unique nodes in the
>>> file, you can try something like:
>>> NUM_NODES=`sort -u ${PBS_NODEFILE} | wc -l | awk '{print $1}'`
>>> mpdboot -n ${NUM_NODES} -f ${PBS_NODEFILE}
>>> I'm not PBS expert, so there might be an easier way to do that, but
>>> give it a try.
>>> If you are concerned about your process-to-node mapping and want to
>>> check what it is try:
>>> mpiexec -l -n ${NP} hostname
>>> -d
>>> On Tue, 4 Apr 2006, Jeffrey B. Layton wrote:
>>>> No joy. It always screams about not having enough hosts:
>>>> totalnum=16 numhosts=8
>>>> there are not enough hosts on which to start all processes
>>>> I think this because we have two processors per node (ppn=2).
>>>> Consequently PBS_NODEFILE has the hosts repeated. I've
>>>> tried using --totalnum=${NP} --ncpus=2 and this didn't work
>>>> either (same error message).
>>>> Thanks!
>>>> Jeff
>>>>> How about the following 3 lines in your script:
>>>>> mpiexec -machinefile ${PBS_NODEFILE} -n ${NP} ./${EXE}
>>>>> mpdallexit
>>>>> Wei-keng
>>>>>> Good morning,
>>>>>> I hate to bother everyone early in the morning, but I'm
>>>>>> looking for some advice on MPICH2 startup. I've been starting
>>>>>> an mpd on each node in the cluster via,
>>>>>> mpdboot -n 25 -f /home/jlayton/mpd.hosts
>>>>>> where the file mpd.hosts contains a list of all possible hosts.
>>>>>> So I'm basically starting mpd on every node. Then I run the
>>>>>> code using mpiexec
>>>>>> and run mpdallexit after the code is finished to stop all of the
>>>>>> mpds. Notice that I'm using PBS for queuing/scheduling.
>>>>>> This is something of a pain, because we lose nodes for
>>>>>> various projects or training so I'm constantly having to go into
>>>>>> the list of hosts and edit it. I also have to change the count on
>>>>>> the mpdboot command.
>>>>>> Is there a better way to start up MPICH2 codes using PBS?
>>>>>> Thanks!
>>>>>> Jeff
