[MPICH] Problem compiling MPICH2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Sep 30 14:00:47 CDT 2005
OK, try configuring with the option --disable-totalview.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Marko Filipovic
> Sent: Friday, September 30, 2005 10:37 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] Problem compiling MPICH2
> Rajeev Thakur wrote:
> > If you plan to run on a single machine, you can configure
> with the option
> > --with-pm=gforker. That will use a different process
> manager that does not
> > require python.
> Actually, I plan to run on a small cluster (8 machines). The single
> machine solution isn't acceptable.
> Marko
