[MPICH] help self-defined datatype
    Rob Ross
    rross at mcs.anl.gov
    Wed Sep 28 10:06:23 CDT 2005
At least one problem is that your displacements are wrong.  All
displacements are relative to the pointer to the type, not the last
displacement.  So you want:
>     #ifndef FIVE
>       int S=4;
>       MPI_Datatype type[4] = { MPI_DOUBLE, MPI_DOUBLE, MPI_DOUBLE, MPI_DOUBLE};
>       int blocklen[4] = { 1, 1, 1, 1 };
>       MPI_Aint disp[4] = { 0, sizeof(double), 2*sizeof(double), 3*sizeof(double)};
>     #else
>       int S=5;
>       MPI_Datatype type[5] = { MPI_DOUBLE, MPI_DOUBLE, MPI_DOUBLE, MPI_DOUBLE, MPI_DOUBLE};
>       int blocklen[5] = { 1, 1, 1, 1, 1 };
>       MPI_Aint disp[5] = { 0, sizeof(double), 2*sizeof(double), 3*sizeof(double), 4*sizeof(double)};
>     #endif
That explains the "FIVE undefined" behavior, but not what you show for
the defined case.
You should also check that sizeof(Grid) == MPI_Type_extent(GRID), just
to make sure that the compiler isn't doing any weird padding or anything
(very unlikely, but types built on structs are tricky).
Rob
Rob Ross, Math and Comp. Science Division, Argonne National Laboratory
