[MPICH] tests are failing with different numbers
Jerry Mersel
jerry.mersel at weizmann.ac.il
Mon Sep 26 03:37:06 CDT 2005
The data written to the exported/mounted directory gets written and does
not interfere with what's going on with other machines.
Jerry
e.x. Certain uw-imap folder formats are not NFS safe
> What do you mean by that?
> Rob
> Jerry Mersel wrote:
>> Another question...
>> Is MPICH (and,or MPICH2) NFS safe?
>> Regards,
>> Jerry
>>>On Tue, 2005-09-20 at 16:54 +0300, Jerry Mersel wrote:
>>>>Hi:
>>>> I've installed MPICH 1.2.6 on a cluster which consists of several
>>>> dual
>>>>opteron machines running redhat AS 4.0.
>>>> A user, while running an application using 4 processors has brought
>>>>to
>>>> my attention that 2 runs with the same binary results in 2 different
>>>> sets of results.
>>>> I then ran the tests that come with mpich (I know I should have
>>>> done
>>>>it before, we just won't tell anybody). And come up with errors, Here
>>>>are they
>>>> are:
>>>> Differences in issendtest.out
>>>> Differences in structf.out
>>>> *** Checking for differences from expected output ***
>>>> p0_3896: p4_error: net_recv read: probable EOF on socket:
>>>> 1
>>>> p0_10524: p4_error: : 972
>>>> 0 - MPI_ADDRESS : Address of location given to MPI_ADDRESS
>>>>does
>>>>not fit in Fortran integer
>>>> I've tried this with the gcc compiler and the pgi compiler with
>>>> none and many different options - the results are the same.
>>>> I tried using MPICH from the pgi site, the user still got different
>>>> results on different runs.
>>>I've seen something similar to this, firstly structf is testing
>>>something that is mathematically impossible, i.e. storing a (in your
>>>case 64bit) pointer in a 32bit integer. This sometimes works (depending
>>>on what the pointer is) but often doesn't, we have some patches for this
>>>(I believe pgi also ship them) but it's still not a 100% cure. Unless
>>>you actually have an application that suffers from this then you don't
>>>need the patch.
>>>Secondly RedHat AS 4.0 has some odd features that effectively mean your
>>>supposed to get different results from running the same program twice,
>>>in particular it's got exec-shield-randomize enabled which moves the
>>>stack about between runs and it runs a cron job overnight which
>>>randomises the load address of your installed shared library's. This
>>>means that the same binary on two different nodes will have a different
>>>address for the stack and a different address for mmap()/shared
>>>library's.
>>>Most applications however should hide this away from you and MPI itself
>>>is designed to be independent of this type of configuration change, it
>>>is fairly easy to introduce artificial dependencies without meaning to
>>>though.
>>>And of course there are the normal problems of floating point accuracy,
>>>some apps aren't actually supposed to get identical results between
>>>runs, merely similar ones...
>>>Ashley,
