[MPICH] Name Publishing
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Sep 16 08:47:11 CDT 2005
Is there a shared file system between the machines on which the client and
server are running? The version of MPICH2 you are using, I believe, requires
a common file system. It will not be needed in the next release.
Also, you don't need to todo "< /dev/null" on the client, only on the server
if you are running it in the background.
Rajeev
> -----Original Message-----
> From: lunasole at interfree.it [mailto:lunasole at interfree.it]
> Sent: Friday, September 16, 2005 4:24 AM
> To: thakur at mcs.anl.gov; mpich-discuss at mcs.anl.gov
> Subject: Re: RE: RE: [MPICH] Name Publishing
> Hi Rajeev,
> i'd a problem by launching the client on another processor.
> the MPI_Lookup_name returns a portname differents from server.
> this portname is local port and it isn't the server port.
> i launched the server  with mpiexec -n 1 server < /dev/null
> command; i launched the client with mpiexec -n 1 client <
> /dev/null on another machine.
> how can I resolve this?
> thank's
>    Rosalia
> >You need to make sure that you run it as
> >  mpiexec -n 1 server < /dev/null &
> >and not simply
> >  mpiexec -n 1 server &
> >Does the program run after that?
> >Rajeev
> >> -----Original Message----- > From: lunasole at interfree.it
> >[mailto:lunasole at interfree.it] > Sent: Monday, August 29,
> 2005 3:02 AM
> >> Subject: Re: RE: [MPICH] Name Publishing
> >> i used MPICH2 version 1.0.2 on Linux (mpich2-1.0.2p1.tar.gz).
> >> i runned the server in background with mpiexec command.
> >> thank's
> >> >I can run these programs with our latest source in CVS
> >> without any problem.
> >> >Which version of MPICH2 are you using? Try version 1.0.2 if
> >> you are using an
> >> >older version. (I didn't check whether this works with 1.0.2).
> >> >Are you running the server in the background? If so, you
> >> need to do mpiexec -n 1
> >> >Rajeev
> owner-mpich-discuss at mcs.anl.gov
> >> >> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> >> >> Sent: Tuesday, August 02, 2005 2:20 AM
> >> >> To: mpich-discuss at mcs.anl.gov
> >> >> Subject: [MPICH] Name Publishing
> >> >> Hi
> >> >> I impemented a simple application Client/Server using Name
> >> Publishing.
> >> >> I launched Server with mpiexec command. The Server associated
> >> >> a port name with a private name "SERVER".  After I
> >> >> launched client on another machine. It looked the port name
> >> >> up by passing name "SERVER" to MPI_Lookup_name.
> >> >> with LAM I have no problem for this implementation.
> >> >> with MPICH2 i have the following error message on client side:
> >> >>         ercole Name_Server]$ mpiexec -n 1 -path
> >> >> sample_MPICH2_MPI/MPI-2/Name_Server/ client
> >> >>         Port_name= port#32867$description#ercole$rank 0 in
> >> >> job 1  ercole_32771   causedcollective abort of all ranks
> >> >> exit status of rank 0: killed by signal 9
> >> >> What is the problem?
> >> >> Thank's.
> >> >>    Rosalia Salvatore
> >> >> Client and Server implementation:
> >> >> //SERVER
> >> >> #include <stdio.h>
> >> >> #include <mpi.h>
> >> >> #define NUM_LOOP 200
> >> >> #define MAX_DATA 200
> >> >> #define TIMER_ELAPSED \
> >> >>  ( ( tv2.tv_usec - tv1.tv_usec ) \
> >> >>   + ( ( tv2.tv_sec - tv1.tv_sec) * 1.E6 ) )
> >> >> int main (int argc, char* argv[])
> >> >>  int rank, size,again,i;
> >> >>  static int count=0;
> >> >>  MPI_Comm client;
> >> >>  MPI_Status status;
> >> >>  char port_name[MPI_MAX_PORT_NAME];
> >> >>  double buf[MAX_DATA];
> >> >>  int time[NUM_LOOP];
> >> >>  MPI_Init(&argc,&argv); /* Initialize MPI */
> >> >>  MPI_Comm_rank(MPI_COMM_WORLD, &rank); /* Get rank */
> >> >>  MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the LAM
> >> >> universe */
> >> >>  if (size != 1)
> >> >>   printf("Error");
> >> >>   return -1;
> >> >>  //printf("CIAO\n");
> >> >>  MPI_Open_port (MPI_INFO_NULL,port_name);
> >> >>  printf("port_name= %s\n", port_name);
> >> >>  MPI_Publish_name("SERVER",MPI_INFO_NULL,port_name);
> >> >>  printf("waiting...\n");
> >> >>  while(1)
> >> >>   MPI_Comm_accept (port_name, MPI_INFO_NULL, 0,
> >> >> MPI_COMM_WORLD, &client);
> >> >>   again=1;
> >> >>   while (again == 1)
> >> >>    printf("\nReceive\n");
> >> >> MPI_Recv(buf,MAX_DATA,MPI_DOUBLE,MPI_ANY_SOURCE,MPI_ANY_TAG,
> >> >> client, &status);
> >> >>    MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, 2, client);
> >> >>    printf("MPI_TAG =%d\n ", status.MPI_TAG);
> >> >>    switch(status.MPI_TAG)
> >> >>     case 0:
> >> >>      MPI_Comm_free(&client);
> >> >>      MPI_Close_port(port_name);
> >> >>      MPI_Finalize();
> >> >>      return 0;
> >> >>     case 1:
> MPI_Comm_disconnect(&client);
> >> >> 					again =0;
> >> >> 					break;
> >> >> 				case 2:
> >> >> 					//for
> (i=0;i<MAX_DATA;i++)
> printf("buf[%d]= %f",1,buf[1]);
> >> >> 					//}//end for
> >> >> 					break;
> >> >> 				default:
> >> >>      MPI_Abort (MPI_COMM_WORLD,1);
> >> >>      break;
> >> >>    } //end of switch
> >> >>   } //end while again
> >> >> } //infinity
> >> >> // CLIENT
> >> >> #include <stdio.h>
> >> >> #include <mpi.h>
> >> >> #include <sys/time.h>
> >> >> #define LOOP 10000
> >> >>  int rank, size,i, tag=0, done=1;
> >> >>  MPI_Comm server;
> >> >>  MPI_Status status;
> >> >>  double var=0.0;
> >> >>    int time[LOOP];
> >> >>  struct timeval tv1, tv2;
> >> >>  FILE *fp;
> >> >>  long max=0, min=20000000;
> >> >>  //MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the
> >> >> LAM universe */
> >> >>  MPI_Lookup_name("SERVER", MPI_INFO_NULL, port_name);
> >> >>  printf("\nMPI_Lookup_name Port_name= %s", port_name);
> >> >>  MPI_Comm_connect (port_name, MPI_INFO_NULL,0,
> >> >> MPI_COMM_WORLD, &server);
> >> >>   for (i=0;i<MAX_DATA;i++)
> >> >>   buf[i]= i*2.0;
> >> >>   //printf("buf[%d]= %f\t",i,buf[i]);
> >> >>  tag=2;
> >> >>  for(i=0;i<LOOP;i++)
> >> >>   gettimeofday(&tv1, NULL);
> >> >>   MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, tag, server);
> >> >> server, &status);
> >> >>   gettimeofday(&tv2, NULL);
> >> >>   time[i]=(int)TIMER_ELAPSED;
> >> >>   printf("\nsend and receive con buf[%d]= %f\n",1,buf[1]);
> >> >>   printf("Client Tempo[%d]= %d\n",i, time[i]);
> >> >>  } //end for
> >> >>  tag=1;
> >> >> 	printf("\nSend con tag 1\n");
> >> >> 	MPI_Comm_disconnect(&server);
> >> >> 	MPI_Finalize();
> >> >> 	/* *************** TIME RESULTS ***************** */
> >> >> 	fp= fopen("Results.txt","w");
> >> >> 	for(i=0;i<LOOP;i++)
> >> >> 		fprintf(fp,"%d    %ld \n", i+1 ,time[i]);
> >> >> 		var=var+time[i];
> >> >> 		if(time[i]<min) min=time[i];
> >> >>     		if(time[i]>max) max=time[i];
> >> >> 	var=var/LOOP-1;
> >> >> 	printf("Tempo del client %d = %f usec\n",rank,var);
> >> >>  fprintf(fp,"LATENCY TIME MIN = %ld microsec\n", min);
> >> >>  fprintf(fp,"LATENCY TIME MAX = %ld microsec\n", max);
> >> >>  fprintf(fp,"LATENCY TIME AVERAGE = %f microsec\n", var);
> >> >>  fclose (fp);
> >> >>  return 0;
> >> >> Visita http://domini.interfree.it, il sito di Interfree
> >> dove trovare
> >> >> soluzioni semplici e complete che soddisfano le tue esigenze
> >> >> in Internet,
> >> >> ecco due esempi di offerte:
> >> >> -  Registrazione Dominio: un dominio con 1 MB di spazio disco
> >> >> +  2 caselle
> >> >>    email a soli 18,59 euro
> >> >> -  MioDominio: un dominio con 20 MB di spazio disco + 5
> >> caselle email
> >> >>    a soli 51,13 euro
> >> >> Vieni a trovarci!
> >> >> Lo Staff di Interfree
> dove trovare
> >> in Internet,
> >> +  2 caselle
> caselle email
> >>    a soli 51,13 euro
> >> Vieni a trovarci!
> Visita http://domini.interfree.it, il sito di Interfree dove trovare
> in Internet,
> +  2 caselle
> -  MioDominio: un dominio con 20 MB di spazio disco + 5 caselle email
>    a soli 51,13 euro
> Vieni a trovarci!
