[MPICH] Enabling TotalView
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri Sep  9 12:30:53 CDT 2005
> When --enable-totalview is used during the configure step for
> mpich2-1.0.2p1, does anything change for message passing? We
> are running Linux RedHat 9 on a 5-node heterogeneous cluster.
> Python 2.3.5 is installed.
MPICH2 doesn't support heterogeneity yet, so that may be the problem.
Rajeev
> Earlier, we had not enabled TotalView. A test case with
> streaming data operated as expected. Now, having enabled
> TotalView, we are getting reports of -nan and -inf after
> accumulating sub-set results. Running the code on any one
> node yields the expected results. In none of the tests was
> TotalView actually activated. We just ran the tests directly,
> as before, using mpiexec. We rebuilt the application after
> installing the new MPICH2 on the main node and copying the
> bin directory to all the other nodes.
> Thanks for any insights you may have.
> Best,
> Peter.
