[MPICH] about MPI_Reduce
llwaeva at 21cn.com
llwaeva at 21cn.com
Tue Oct 18 02:05:37 CDT 2005
> The attached small test program produces the expected output with mpich-1.2.6:
> $ mpicc -Wall -W -Wno-unused -O2 -g -std=c99 reduce.c -o reduce
> $ mpirun -np 10 ./reduce
> 10 0 30 0 50 0 70 0
> BTW: Identical output is produced when I compile and run the program with
> LAM 7.1.1.
Thanks for your program. It does work. I found the problem is in the
reduction function. In your code, everything is all right
void reduction(int *in, int *inout, int *len, MPI_Datatype *dptr)
assert(*dptr == datatype);
for (int l=0; l<(*len); l++)
for (int i=0; i<vlength; i++)
if (i%2==0) inout[i] += in[i];
However, if I change the array operation to pointer operation (as the book
"MPI: The complete reference" do), the result is wrong
{ int l, i;
for (l=0; l<(*len); l++)
for (i=0; i<vlength; i++)
if (i%2==0) {*inout += *in; inout++; in++;}
I am wondering what's going on
