[MPICH] Crash While Spawning Process
David Ashton
ashton at mcs.anl.gov
Tue Oct 18 01:25:26 CDT 2005
Jason,
After modifying your example to correct syntax errors I ran the job like
this:
C:\Temp>"\Program Files\MPICH2\bin\mpiexec.exe" -exitcodes -n 1
\\grass\c$\temp\myapp.exe
Parent com: 4000000
Error: This MPI Implementation doesn't support universe size.
Spawning...
Parent com: 84000000
Spawned.
rank: node: exit code
0: hopper: 0
Parent com: 84000001
Enter the number of intervals: (0 quits) 342
pi is approximately 3.1415933660597268, Error is 0.0000007124699337
wall clock time = 0.002582
Enter the number of intervals: (0 quits) 0
0: hopper: 0
1: hopper: 0
Everything went fine without any crashing.
But you aren't going to get a valid value for universe size. MPICH2 for
Windows currently doesn't support that value.
-David Ashton
Here's the code I ran:
/* -*- Mode: C; c-basic-offset:4 ; -*- */
* (C) 2001 by Argonne National Laboratory.
* See COPYRIGHT in top-level directory.
/* This is an interactive version of cpi */
#include "mpi.h"
#include <stdio.h>
#include <math.h>
double f(double);
double f(double a)
return (4.0 / (1.0 + a*a));
int main(int argc,char *argv[])
int done = 0, n, myid, numprocs, i;
double PI25DT = 3.141592653589793238462643;
double mypi, pi, h, sum, x;
double startwtime = 0.0, endwtime;
int namelen;
char processor_name[MPI_MAX_PROCESSOR_NAME];
MPI_Comm parentComm;
MPI_Init(&argc,&argv);
MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
MPI_Comm_rank(MPI_COMM_WORLD,&myid);
MPI_Get_processor_name(processor_name,&namelen);
MPI_Comm_get_parent(&parentComm);
printf("Parent com: %X\n", parentComm); fflush(stdout);
if (myid == 0 && parentComm == MPI_COMM_NULL)
int universeSize, *universeSizep;
int flag;
int result;
MPI_Comm everyone;
MPI_Comm_get_attr(MPI_COMM_WORLD, MPI_UNIVERSE_SIZE, &universeSizep,
&flag);
if (!flag)
printf("Error: This MPI Implementation doesn't support universe
size.\n"); fflush(stdout);
universeSize = 2;
else
universeSize = *universeSizep;
printf("Spawning...\n"); fflush(stdout);
printf("%s\n", argv[0]); fflush(stdout);
result = MPI_Comm_spawn(argv[0], MPI_ARGV_NULL, universeSize,
MPI_INFO_NULL, 0, MPI_COMM_SELF, &everyone,
MPI_ERRCODES_IGNORE);
printf("Spawned.\n"); fflush(stdout);
MPI_Finalize();
return 0;
fprintf(stdout,"Process %d of %d is on %s\n",
myid, numprocs, processor_name);
fflush(stdout);
while (!done) {
if (myid == 0) {
fprintf(stdout, "Enter the number of intervals: (0 quits) ");
fflush(stdout);
if (scanf("%d",&n) != 1) {
fprintf( stdout, "No number entered; quitting\n" );
n = 0;
startwtime = MPI_Wtime();
MPI_Bcast(&n, 1, MPI_INT, 0, MPI_COMM_WORLD);
if (n == 0)
done = 1;
else {
h = 1.0 / (double) n;
sum = 0.0;
for (i = myid + 1; i <= n; i += numprocs) {
x = h * ((double)i - 0.5);
sum += f(x);
mypi = h * sum;
MPI_Reduce(&mypi, &pi, 1, MPI_DOUBLE, MPI_SUM, 0,
MPI_COMM_WORLD);
if (myid == 0) {
printf("pi is approximately %.16f, Error is %.16f\n",
pi, fabs(pi - PI25DT));
endwtime = MPI_Wtime();
printf("wall clock time = %f\n", endwtime-startwtime);
fflush( stdout );
MPI_Finalize();
return 0;
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jason Surratt
Sent: Monday, October 17, 2005 7:28 AM
To: MPICH Mailing List
Subject: [MPICH] Crash While Spawning Process
Hello,
I am new to MPI, but I am very happy with the initial success I've had
parallelizing my application with MPICH2.
The problem I'm having is when I spawn a process with the MPI_Comm_spawn
function. To keep things simple I have modified the icpi.c example to
include the following code snippet after line 35:
int flag;
&flag);
if (!flag)
universeSize = 2;
else
int result;
MPI_Comm everyone;
MPI_INFO_NULL, 0, MPI_COMM_SELF, &everyone, MPI_ERRCODES_IGNORE);
MPI_Finalize();
return 0;
I then launch this application with:
mpiexec -exitcodes -n 1 \\jsurratt-laptop\simple_mpi\simple_mpi
My intent is to launch universeSize processes without requiring the user
to type the size at the command line.
If I run this code with my local machine as the only host the universe
size is not returned (flag == 0), but the application spawns two
processes and runs fine.
If I add another similarly configured machine to my host list the
universe size is not returned (flag == 0) and I get the standard Windows
crash prompt 'Process launcher for MPICH2 applications has encountered a
problem and needs to close. We are sorry for the inconvenience.' when
the MPI_Comm_spawn function is called.
I'm hoping that I'm just doing something silly, but if need be I can
bring it up in the debugger and post more information.
I'm using the following configuration on all machines:
Windows XP SP2
MPICH2 v1.0.2-1 (ia32)
Running the unmodified version of icpi.c with multiple hosts works fine.
Thanks in advance,
-Jason
