[MPICH] Building pman_vis
David Ashton
ashton at mcs.anl.gov
Sat Nov 26 16:30:05 CST 2005
Make sure you are using the newly released MPICH2 1.0.3. The "Application
failed to initialize properly" error is a bug in the 1.0.2 code. Do a "dir
%windir%\system32\*mpich2*" and if the dates on the dlls are not from
November 2005 then you don't have the correct binaries installed.
http://www.mcs.anl.gov/mpi/mpich2
-David Ashton
-----Original Message-----
From: peter_raeth at juno.com [mailto:peter_raeth at juno.com]
Sent: Saturday, November 26, 2005 8:02 AM
To: peter_raeth at juno.com
Cc: ashton at mcs.anl.gov; peter_raeth at juno.com; mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] Building pman_vis
Made a copy of the original pman_vis directory.
Pointed the compiler and linker at the appropriate directories in the binary
installation directory structure.
Changed mpid.lib to mpi.lib.
Compile and link went just fine. An attempt at running the program (pressed
! in Vistual Studio) yielded the error, "The application failed to
initialize properly."
The cpi project went well using this approach but pman_vis is a C++ program.
When I tried another C++ program using the cpi project setup, the same error
occurred. That is why I switched to looking at pman_vis, since cpi is a C
program.
Like as not I am missing something in Visual Studio. Would appreciate your
insights. Thanks.
