[MPICH] Question about MPICH2 on a single machine
Rajeev Thakur thakur at mcs.anl.gov
Wed Nov 23 15:38:20 CST 2005
You should try out the recently released version 1.0.3. With mpd, you need
to do "mpd &" before running "make testing". If any errors occur at that
point, let us know.
You can use "mpiexec" to run an MPI program instead of mpirun.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Zaiwen Wen
> Sent: Wednesday, November 23, 2005 3:20 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Question about MPICH2 on a single machine
> Recently, I'm installing MPICH2 on a single machine and have
> tried two
> versions:
> 1. --with-pm=mpd
> When I try "make testing", the following error occured:
> mpdrun_dyn-128-59-150-217.dyn.columbia.edu: cannot connect to
> local mpd
> (/tmp/mpd2.console_wenzw); possible causes:
>    1. no mpd is running on this host
>    2. an mpd is running but was started without a "console"
> (-n option)
> Anyway, if I start "mpd&" first, and then "make testing", it
> can not find
> the host.
> Question: How can I configure it to run on a single manchine?
> 2. --with-pm=gforker
> My configuration is:
> /home/code/mpich/mpich2-1.0.2p1/configure 2>&1 -prefix=/opt/mpich2/
> --with-pm=gforker  | tee configure.log
> After installation,  directory "bin" contains the following files:
> clog2_print  mpicc  mpich2version  mpicxx  mpiexec  mpif77  mpif90
> When I try "make testing", it prompted that all 354 tests passed!
> I can not find " mpirun". Is the installation right? Anyway, some
> applications need "mpirun", how can I solve this problem?
> Thanks and Happy Thanksgiving!
> Zaiwen
