[MPICH] Question about MPICH2 on a single machine
William Gropp gropp at mcs.anl.gov
Wed Nov 23 15:29:27 CST 2005
At 01:19 PM 11/23/2005, Zaiwen Wen wrote:
>2. --with-pm=gforker
>My configuration is:
>/home/code/mpich/mpich2-1.0.2p1/configure 2>&1 -prefix=/opt/mpich2/
>--with-pm=gforker  | tee configure.log
>After installation,  directory "bin" contains the following files:
>clog2_print  mpicc  mpich2version  mpicxx  mpiexec  mpif77  mpif90
>When I try "make testing", it prompted that all 354 tests passed!
>I can not find " mpirun". Is the installation right? Anyway, some
>applications need "mpirun", how can I solve this problem?
MPICH2 uses "mpiexec", as recommended by the MPI-2 standard, for process
startup.  For simple use, you can set a link from mpiexec to mpirun, e.g.,
cd mpich2/bin
ln -s mpiexec mpirun
Applications should switch to mpiexec, as that is the only portable way to
start MPI processes.  Up-to-date MPI implementations will provide mpiexec .
Bill
William Gropp
http://www.mcs.anl.gov/~gropp
