[MPICH] about C++ and SEEK_SET
Rajeev Thakur
thakur at mcs.anl.gov
Mon Nov 21 11:16:47 CST 2005
You can include mpi.h before including stdio.h or iostream.
OR
You can pass -DMPICH_IGNORE_CXX_SEEK as an argument when compiling your
program.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Zaiwen
> Sent: Monday, November 21, 2005 10:24 AM
> To: mpich-discuss
> Subject: [MPICH] about C++ and SEEK_SET
> Hi, I encountered a problem during making package "Trilinos"
> with mpi. The error information was:
> SEEK_SET is #defined but must not be for the C++ binding of MPI
> The following is the solution from mpich2 FAQ:
> C++ and SEEK_SET
> Some users may get error messages such as
> The problem is that both stdio.h and the MPI C++ interface
> use SEEK_SET, SEEK_CUR, and SEEK_END. This is really a bug in
> the MPI-2 standard. You can try adding
> #undef SEEK_SET
> #undef SEEK_END
> #undef SEEK_CUR
> before mpi.h is included, or add the definition
> to the command line (this will cause the MPI versions of
> SEEK_SET etc. to be skipped).
> I've tried the first solution -- modify every include file
> and c++ source file which errors occured. However, I can't
> get through compiling a file "ml_agg_min_energy.cpp". It
> required definitions of "SEEK_SET, SEEK_END, SEEK_CUR" for
> "stdio.h". I can not figure out which ".h" file introduced
> such confliction although I change the order of declaration
> of "stdio.h" and "mpi.h" in some files.
> My questions is :
> 1. Is there any simple solution rather modifing file by file?
> 2. How to figure out the second solution, say, how to
> add the definition " -DMPICH_IGNORE_CXX_SEEK" to the
> command line ? The meaning is vague here. Is this solution
> simpler than the first solution?
> Thank you so much!
> With my Best!
> Zaiwen
