[MPICH] Error while running an MPI program using MPICH
Prakash Velayutham prakash.velayutham at cchmc.org
Sat Nov 12 11:40:08 CST 2005
Hello All,
I was wrong to think it is solved. The problem remains. My setup is as
follows:
SuSE Pro 9.3 with mpich-1.2.7p1, mpiexec-0.80 (from OSC), torque-1.2.0p5.
Head node is a Intel Xeon (not EM64T) where these software are compiled.
The execution host is a Intel P3 system. Would that change anything?
The error returned is:
p0_7360:  p4_error: interrupt SIGx: 15
I compiled mpich with
/configure --with-comm=shared --with-device=ch_p4 --without-romio
-prefix=/usr/local/mpich-1.2.7p1 -rsh=/usr/bin/ssh --enable-sharedlib
and mpiexec with
/configure --prefix=/usr/local/mpiexec-0.80
--with-pbs=/usr/local/torque-1.2.0p5 --with-default-comm=mpich-p4
--with-mpicc=/usr/local/mpich-1.2.7p1/bin/mpicc
--with-mpif77=/usr/local/mpich-1.2.7p1/bin/mpif77
Any suggestions?
Prakash
Prakash Velayutham wrote:
> Hi,
> I sorted that out. It is not mpich but OSC's mpiexec that causes that
> error. I have to dig deeper to find out why and what configure options
> cause this. Anyway, thanks. If I have something more, I will let you
> all know.
> Prakash
>> Hi Shaun,
>> The same code used to run on SuSE Pro 9.0 with mpich-1.2.6. Any
>> pointers please?
>> Thanks,
>> Prakash
>> Shaun Q wrote:
>>> Does it work on any other setup (a non-suse machine or an older
>>> setup for example?)
>>> Shaun Qualheim
>>> Convergent Thinking
>>> On Thu, 10 Nov 2005, Prakash Velayutham wrote:
>>>> Hi,
>>>> I am using MPICH 1.2.7 under SuSE Pro 9.3 (kernel - 2.6.11.4-21.9).
>>>> When I run an MPI program, after about 4 hours (not consistent
>>>> though), I get this error. Does anyone know how to resolve this?
>>>> p0_4476:  p4_error: interrupt SIGx: 15
>>>> I used to get errors about ipcs earlier ( a year back or so), but I
>>>> clean up using cleanipcs.
>>>> Thanks,
>>>> Prakash
