Regarding UNIVERSE_SIZE
William Gropp
gropp at mcs.anl.gov
Wed May 25 17:14:00 CDT 2005
At 04:28 PM 5/25/2005, Prakash Velayutham wrote:
>Hi,
>How is the implementation of UNIVERSE_SIZE in mpich2? Does anyone know. I
>would like to know if it can be varied during a MPI run by the scheduler?
>I am looking at it from MPI_Comm_spawn point of view. If I can modify this
>variable from the scheduler's end when more processors are available and
>check for this variable from inside the application, then I can
>effectively use the spawn to get newer nodes from inside of scheduler
>environment. I understand it is not that straight forward, but it is
>hackable, right?
Section 5.5.1 of the MPI-2 standard says:
MPI UNIVERSE SIZE is initialized in MPI INIT and is not changed by MPI.
This was done to avoid the race conditions implicit in allowing
MPI_UNIVERSE_SIZE to change. The standard goes on to say that if the
application wants more up-to-date information, it must communicate with the
process management system.
Note that MPI_UNIVERSE_SIZE is not a maximum, so it doesn't limit the
ability of the app to create more processes if the process management
system allows that.
Bill
>Any words from developers, please?
>Regards,
>Prakash
William Gropp
http://www.mcs.anl.gov/~gropp
