[MPICH] ROMIO MPI_FILE_WRITE ALL
Stephen Scott stephen.scott at imperial.ac.uk
Tue Jun 28 13:52:12 CDT 2005
Dear list,
I have a question/problem related to the use of MPI_FILE_WRITE_ALL from
the ROMIO package.  I want to write a distributed 4D fortran array to
file using the ROMIO library.  The array is divided along the third
dimension.   A section of the code is listed below.
The purpose of the subroutine is to write the 4D fluid_uk(:,:,:,:)
distributed array to file on node 0.  However, I get a compile time
error for the call to MPI_FILE_WRITE_ALL  - 'There is no matching
specific subroutine for this generic subroutine call.
[MPI_FILE_WRITE_ALL]'
I presumed that MPI_FILE_WRITE_ALL would accept an array of any
dimension but it appears I am wrong.  I would be most grateful for any
feedback or suggestions for the list!
Thanks in advance!
Steve
mpich-1.2.6
intel compilers 8.0
Red Hat Enterprise Linux WS release 3 (Taroon Update 1)
SUBROUTINE fluid_restart_write(time,ierr)
    USE precision
    USE fluid_arrays,    ONLY : fluid_uk
    USE domain_params,   ONLY : ni,nj,nk
    USE mpi
    IMPLICIT NONE
    INTEGER,INTENT(INOUT)           :: ierr
    INTEGER,INTENT(IN)              :: time
    INTEGER                         :: myrank
    INTEGER                         :: nprocs
    INTEGER*8                       :: disp=0
    CHARACTER(len=100)              :: tstep
    CHARACTER(len=10)               :: execute_date
    CHARACTER(len=10)               :: execute_time
    INTEGER,PARAMETER               :: MASTER = 0
    INTEGER                         :: gsizes(4)
    INTEGER                         :: distribs(4)
    INTEGER                         :: dargs(4)
    INTEGER                         :: psizes(4)
    INTEGER                         :: local_size
    INTEGER                         :: PANDORA_RESTART_TYPE
    INTEGER                         :: PANDORA_RESTART_FILE
    INTEGER                         :: PANDORA_COMM
    INTEGER                         :: status(MPI_STATUS_SIZE)
    CALL MPI_COMM_RANK(MPI_COMM_WORLD,myrank,ierr)
    CALL MPI_COMM_SIZE(MPI_COMM_WORLD,nprocs,ierr)
    gsizes   = (/ni,nj,nk,3/)
    distribs = MPI_DISTRIBUTE_BLOCK
    dargs    = MPI_DISTRIBUTE_DFLT_DARG
    psizes   = (/1,1,nprocs,1/)
    CALL
MPI_TYPE_CREATE_DARRAY(nprocs,myrank,4,gsizes,distribs,dargs,psizes, &
MPI_ORDER_FORTRAN,MPI_DOUBLE_COMPLEX,PANDORA_RESTART_TYPE,ierr)
    CALL MPI_TYPE_COMMIT(PANDORA_RESTART_TYPE,ierr)
    ! fname_frestart defined earlier in module
    CALL
MPI_FILE_OPEN(MPI_COMM_WORLD,fname_frestart,MPI_MODE_WRONLY+MPI_MODE_CRE
ATE, &
                       MPI_INFO_NULL,PANDORA_RESTART_FILE,ierr)
    CALL
MPI_FILE_SET_VIEW(PANDORA_RESTART_FILE,disp,MPI_DOUBLE_COMPLEX,PANDORA_R
ESTART_TYPE, &
                           "native",MPI_INFO_NULL,ierr)
    ! fluid_uk(ni,nj,nk/nprocs,3)
    local_size = ni*nj*(nk/nprocs)*3
    CALL
MPI_FILE_WRITE_ALL(PANDORA_RESTART_FILE,fluid_uk,local_size,MPI_DOUBLE_C
OMPLEX,status,ierr)
    CALL MPI_FILE_CLOSE(PANDORA_RESTART_FILE,ierr)
END SUBROUTINE
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20050628/95e73f11/attachment.bin>
