[MPICH] MPICH2 use of shared memory
David Ashton
ashton at mcs.anl.gov
Wed Jun 15 13:50:22 CDT 2005
James,
The MPICH2 ssm channel allocates shared memory on demand when processes on
the same node first communicate with each other. A fixed amount of shared
memory is allocated for each queue. If you have too many queues on a single
node you will eventually run out of shared memory as determined by the
system but MPICH2 does not impose any maximum.
-David Ashton
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of James S Perrin
Sent: Wednesday, June 15, 2005 9:57 AM
Subject: [MPICH] MPICH2 use of shared memory
Under MPICH 1 the p4 device required the P4_GLOBMEMSIZE setting to
the amount
of shared memory available. Is there an equivalent or need of one when using
MPICH2's ch3:ssm device?
Regards
James
James S. Perrin, | email: james.perrin at manchester.ac.uk
Manchester Visualization Centre, | www.sve.man.ac.uk/General/Staff/perrin
Kilburn Building, The University, | tel: +44 161 275 6945
Manchester, England. M13 9PL. | fax: +44 161 275 6800/6040
"The test of intellect is the refusal to belabour the obvious" -Alfred
Bester
