[MPICH] rsh problem on Linux
Jeffrey B. Layton
laytonjb at charter.net
Mon Jun 13 16:13:33 CDT 2005
I get the usual "Connection refused" message from tstmachine.
When I run my code I get the same thing (when running the
code I've tried a hosts file and '-all-local' options with the
same results).
Thanks!
Jeff
>What behavior do you observe for now? No error message, wrong distribution to
>the nodes or only local execution? - Reuti
>Quoting "Jeffrey B. Layton" <laytonjb at charter.net>:
>>I did all of those :) Is there a -verbose option in mpirun
>>to see what it's doing?
>>Thanks!
>>Jeff
>>>Hi,
>>>the default in MPICH 1.2.6 is to use ssh. You have three possibilites to
>>solve
>>>it:
>>>1. ./configure -rsh=rsh ...
>>>2. export RSH_COMMAND=rsh and then ./configure ...
>>>3. at execution time before mpirun: export P4_RSHCOMMAND=rsh
>>>Cheers - Reuti
>>>>Howdy gang!
>>>> I'm trying to test a simple MPI code built with MPI 1.2.6
>>>>and the Intel 8.1 compilers on a single CentOS 4 box (RHEL
>>>>rebuild). As a user, from the command line, I can rsh to
>>>>the box, but when I run tstmachines or any simple MPI
>>>>code, they can't seem to rsh to the box.
>>>> I'm still looking at the rsh configuration, but does anyone
>>>>have any idea how to fix this or where to look?
>>>>Thanks!
>>>>Jeff
