[MPICH] Compile errors with MPICH2 1.0.2
    Anthony Chan
    chan at mcs.anl.gov
    Mon Jun 13 14:13:50 CDT 2005
You should unset CC, F77 and F90, CFLAGS, FFLAGS and only set -xarch=v9b
through CC, CXX, F77 and F90.  It seems that CFLAGS was picked up
through your environment.  This caused mixing of 32bit with 64bit
binaries.
A.Chan
On Mon, 13 Jun 2005, Mike Newton wrote:
> Here they are:
> /opt/SUNWspro/bin/cc -I.. -I/usr/java/include -
> I/usr/java/include/solaris -
> I/fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_sample/../src/logformat/trace -xarch=v9b -c trace_impl.c
> I/fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_sample/../src/logformat/trace -xarch=v9b -c /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_sample/../src/logformat/trace/trace_print.c
> o /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_sample/bin/textlog_print trace_impl.o trace_print.o
> ld: fatal: file trace_impl.o: wrong ELF class: ELFCLASS64
> ld: fatal: File processing errors. No output written
> to /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_sample/bin/textlog_print
> *** Error code 1
> make: Fatal error: Command failed for target `textlog_print'
> Current working
> directory /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_sample/src
> *** Error code 1
> make: Fatal error: Command failed for target `all'
> Current working
> o /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_rlog/bin/rlog_print trace_input.o rlogutil.o trace_print.o
> ld: fatal: file trace_input.o: wrong ELF class: ELFCLASS64
> to /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_rlog/bin/rlog_print
> *** Error code 1
> make: Fatal error: Command failed for target `rlog_print'
> Current working
> directory /fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2/src/slog2sdk/trace_rlog/src
> *** Error code 1
> On Mon, 2005-06-13 at 13:48 -0500, Anthony Chan wrote:
> > I don't see any error at all in my build with my configure command.
> > I would like to know what compile error you have on slog2sdk besides what
> > you listed in your first email.
> > A.Chan
> > > Except for some compile errors on slog2sdk, this seemed to work. Thanks.
> > > I'll package it and have my users give it try.
> > > On Mon, 2005-06-13 at 12:11 -0500, Anthony Chan wrote:
> > > > The following configure command works on our solaris box:
> > > > /sandbox/chan/mpich2_work/mpich2-1.0.2/configure
> > > > --prefix=/sandbox/chan/mpich2_work/install_102_shm --enable-f77
> > > > --enable-f90 --with-pm=gforker
> > > > CC="/opt/SUNWspro/bin/cc -xarch=v9b"
> > > > F77="/opt/SUNWspro/bin/f77 -xarch=v9b"
> > > > F90="/opt/SUNWspro/bin/f90 -xarch=v9b"
> > > > TRACE_CC=/opt/SUNWspro/bin/cc
> > > > LD=/usr/ccs/bin/ld | tee c.txt ; make | tee m.txt ;
> > > > make install ; make installcheck
> > > > If there is still error, send us your configure and make output, i.e.
> > > > c.txt and m.txt.
> > > > A.Chan
> > > > On Mon, 13 Jun 2005, Dieter an Mey wrote:
> > > > > I guess you forgot to add
> > > > > 	-xarch=v9b
> > > > > to the link command, in order to tell the linke to build a 64 bit binary.
> > > > > best regards
> > > > > Dieter
> > > > > Mike Newton wrote:
> > > > > > I ran into the following errors while trying to compile MPICH2 1.0.2.
> > > > > > My Environment:
> > > > > >   SunFire 12K domain of 12 CPUs
> > > > > >   Solaris 9
> > > > > >   Sun Studio Pro Compilers (C & Fortran)
> > > > > > Environment varibles:
> > > > > >  FC=/opt/SUNWspro/bin/f90
> > > > > >  F77=/opt/SUNWspro/bin/f77
> > > > > >  F90=/opt/SUNWspro/bin/f90
> > > > > >  CFLAGS=-xarch=v9b
> > > > > >  FFLAGS=-xarch=v9b
> > > > > > Configure statement:
> > > > > >  ./configure --prefix=/usr/local/mpich2 --enable-f77 --enable-f90 \
> > > > > >  --with-device=ch3:shm --with-pm=gforker
> > > > > > Errors:
> > > > > > make[5]: *** [rlog_print] Error 1
> > > > > > make[4]: *** [all] Error 2
> > > > > > make[3]: [all] Error 2 (ignored)
> > > > > > make[2]: Leaving directory
> > > > > > `/fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/mpe2'
> > > > > > /opt/SUNWspro/bin/cc  -o mpiexec mpiexec.o  -L../util -lmpiexec \
> > > > > > -L../../../lib -lmpich -lrt     -lrt   -lnsl -lsocket
> > > > > > ld: fatal: file mpiexec.o: wrong ELF class: ELFCLASS64
> > > > > > ld: fatal: File processing errors. No output written to mpiexec
> > > > > > make[3]: *** [mpiexec] Error 1
> > > > > > make[3]: Leaving directory
> > > > > > `/fs/users/sysadmin/jmnewton/Build/mpich2-1.0.2/src/pm/gforker'
> > > > > Dieter an Mey
> > > > > High Performance Computing               Hochleistungsrechnen
> > > > > RWTH Aachen University                   Rechen- und Kommunikations-
> > > > > Center for Computing and Communication   zentrum der RWTH Aachen
> > > > > phone: ++49-(0)241-80-24377              Seffenter Weg 23
> > > > > fax:   ++49-(0)241-80-22134              52074 Aachen, Germany
> > > > > email: anmey at rz.rwth-aachen.de
> > > Mike Newton <jmnewton at duke.edu>
