[MPICH] Re: New version of MPICH2 (1.0.2)
    Trach-Minh Tran
    trach-minh.tran at epfl.ch
    Sun Jun 12 04:15:59 CDT 2005
On 06/12/2005 08:04 AM, Trach-Minh Tran wrote:
> On 06/12/2005 02:20 AM, Rusty Lusk wrote:
>>> - The mpdrun/mpirun did not export the current LD_LIBRARY_PATH
>>> environment variable.
>>>   It seems however that it does export the other variables (PATH,
>>> PWD, ...) !
>>>   Spawning the processes with mpdboot and mpirun from the 1.0.1
>>> version appears to
>>>   work with codes compiled with the 1.0.2 version!
>> You will want to use the MPI-2 standard 'mpiexec' instead of mpirun.
>> By default, it should export all environment variables.  Let us know if
>> it doesn't.
> Both mpiexec and mpdrun fail to export LD_LIBRARY_PATH, as mpirun. It is
> strange that it seems that all environment variables are exported *except*
> LD_LIBRARY_PATH!
Ok, I have just found out that the setuid bit of "mpdroot" was set! After removing
it, mpirun/mpdrun/mpiexec work as expected now :-) May be somebody can explain me
why?
Best regards,
T.M. Tran
