[MPICH] Problems installing MPICH2 on single machine
Rajeev Thakur thakur at mcs.anl.gov
Wed Jul 13 13:00:38 CDT 2005
>    ** ssh timed out to a.me.org
>    ** ssh failed to a.me.org
These lines from mpdcheck suggest that ssh is not working right on your
machine.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of James Frye
> Sent: Monday, July 11, 2005 8:25 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Problems installing MPICH2 on single machine
> Hi,
> I'm having problems setting up MPICH2 (and MPICH) to run on a single
> machine, and would be grateful for any help.
> The machine is a Dell laptop with P3 processor, running
> Linux.  Output of
> uname -a is:
> Linux a.me.org 2.6.5-1.358 #1 Sat May 8 09:04:50 EDT 2004
> i686 i686 i386 GNU/Linux
> The machine is used for development.  It needs to run MPI
> only on itself,
> but sometimes with multiple "processors" (e.g.  "mpirun -np 4
> program") to
> test code that will eventually run on a parallel machine.
> I'm often not
> connected to any network, so I've arbitrarily set HOSTNAME to
> "a.me.org".
> When I am connected, it's often via a DHCP connection, so
> AFAIK (I'm not a
> network guru) there's no way to give it a real, fixed name.
> I've configured & installed per instructions, in directory
> /opt/mpich2/gcc.  Paths & environment are set by sourcing the script
>    #! /bin/csh
>    echo 'Setting MPICH2/gcc paths'
>    setenv MPICH2 /opt/mpich2/gcc
>    setenv PATH $PATH\:${MPICH2}/bin
>    setenv MANPATH $MANPATH\:${MPICH2}/man
> "mpd &" starts, "mpdtrace -l" responds with "a.me.org_32811".
> "mpiexec -n 1 /bin/hostname" will eventually time out with
> messages like
>    a.me.org_mpdman_1: conn error in connect_lhs: Connection timed out
>    a.me.org_mpdman_0: mpd_uncaught_except_tb handling:
>      socket_error: (110, 'Connection timed out')
> "mpdcheck" and "mpdcheck -f mpd.hosts" give no output.
> "mpdcheck -f mpd.hosts -ssh"
> gives
>    ** here is the output:
> (but there is no output.)
> If instead I use "localhost" in the mpd.hosts file, I get
>    ** Timed out waiting for client on localhost to produce output.
>    client on localhost failed to access the server.
>    here is the output:
> and again, no output.
> I get similar problems with MPICH (the most recent version,
> downloaded &
> installed yesterday).  It tries to use rsh instead of ssh,
> and can only
> run with "-np 1".
> The problem would seem to be related to the DHCP connection.  I've run
> MPICH for a couple of years on my network at home without
> problems, but
> they're all connected to each other and not the outside world.
> Unfortunately they're about 6000 miles away at the moment,
> and I need to
> get some work done...
> Thanks,
> James
