[MPICH] Mpiexec can't end on MPICH2
    Tao He
    taohe at blue.weeg.uiowa.edu
    Mon Dec 12 18:37:44 CST 2005
I used your idea to run the CPI sample
%mpiexec -n 10 ./cpi
Process 0 of 10 on master
pi is approximately 3.1415926535897452, Error is 0.0000000000000480
wall clock time = 0.285551
Process 2 of 10 on node3
Process 1 of 10 on node2
Process 3 of 10 on node4
Process 4 of 10 on node5
Process 6 of 10 on node7
Process 5 of 10 on node6
Process 8 of 10 on node9
Process 7 of 10 on node8
Process 9 of 10 on node10
CPI can work but this program still couldn't exit. I have to press Ctrl+C to
end it.
Any other idea?
MPD couldn't work in my cluster. I don't know the reason. I just use SMPD.
----- Original Message -----
To: <taohe at blue.weeg.uiowa.edu>
Cc: <thakur at mcs.anl.gov>; <mpich-discuss at mcs.anl.gov>
Sent: Monday, December 12, 2005 5:59 PM
Subject: Re: [MPICH] Mpiexec can't end on MPICH2
> Is there any indication at all that the program starts correctly? On my
> Fedora III cluster I have to use:
>    "%mpiexec -n 10 ./application_name".
> That command line assumes that that application_name is located in the
> default directory on the console machine and in that exact same path on
> all cluster nodes.
> How was MPD started?
