[MPICH] Mpiexec can't end on MPICH2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Dec 12 20:32:53 CST 2005
Why did you select SMPD? Can you try with the default MPD?
Rajeev
  _____
Sent: Monday, December 12, 2005 1:09 PM
To: Rajeev Thakur; mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] Mpiexec can't end on MPICH2
HI, Rajeev,
any MPI program. Even like these command as:
%mpiexec -n 10 hostname
master
node2
No exit. I have to Ctrl+C to end it.
Any suggestion?
Tao
----- Original Message -----
From: Rajeev  <mailto:thakur at mcs.anl.gov> Thakur
To: 'Tao He' <mailto:taohe at blue.weeg.uiowa.edu>  ; mpich-discuss at mcs.anl.gov
Sent: Monday, December 12, 2005 12:54 PM
Subject: RE: [MPICH] Mpiexec can't end on MPICH2
Which MPI program are you running? Do the examples from the MPICH2 examples
directory run, eg, cpi?
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Tao He
Sent: Saturday, December 10, 2005 7:10 PM
Subject: [MPICH] Mpiexec can't end on MPICH2
Hi, All,
I met a problem on MPICH2. I had setup MPICH2 on my Suse Linux cluster. I
chose SMPD as my process manager. All were fine but when I run a mpi program
with mpiexec this program couldn't end. I must use Ctrl+C to terminate this
program. What problem? Who know?
l am very appreciating  your help if you tell me.
os
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20051212/6f646cda/attachment.htm>
