[MPICH] Name Publishing
lunasole at interfree.it
Mon Aug 29 03:01:41 CDT 2005
i used MPICH2 version 1.0.2 on Linux (mpich2-1.0.2p1.tar.gz). i runned the server in background with mpiexec command.
thank's
>I can run these programs with our latest source in CVS without any problem.
>Which version of MPICH2 are you using? Try version 1.0.2 if you are using an
>older version. (I didn't check whether this works with 1.0.2).
>Are you running the server in the background? If so, you need to do mpiexec -n 1
>server < /dev/null &
>Rajeev
>> -----Original Message----- > From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
>> Sent: Tuesday, August 02, 2005 2:20 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [MPICH] Name Publishing
>> Hi
>> I impemented a simple application Client/Server using Name Publishing.
>> I launched Server with mpiexec command. The Server associated
>> a port name with a private name "SERVER". After I
>> launched client on another machine. It looked the port name
>> up by passing name "SERVER" to MPI_Lookup_name.
>> with LAM I have no problem for this implementation.
>> with MPICH2 i have the following error message on client side:
>> ercole Name_Server]$ mpiexec -n 1 -path
>> sample_MPICH2_MPI/MPI-2/Name_Server/ client
>> Port_name= port#32867$description#ercole$rank 0 in
>> job 1 ercole_32771 causedcollective abort of all ranks
>> exit status of rank 0: killed by signal 9
>> What is the problem?
>> Thank's.
>> Rosalia Salvatore
>> Client and Server implementation:
>> //SERVER
>> #include <stdio.h>
>> #include <mpi.h>
>> #define NUM_LOOP 200
>> #define MAX_DATA 200
>> #define TIMER_ELAPSED \
>> ( ( tv2.tv_usec - tv1.tv_usec ) \
>> + ( ( tv2.tv_sec - tv1.tv_sec) * 1.E6 ) )
>> int main (int argc, char* argv[])
>> int rank, size,again,i;
>> static int count=0;
>> MPI_Comm client;
>> MPI_Status status;
>> char port_name[MPI_MAX_PORT_NAME];
>> double buf[MAX_DATA];
>> int time[NUM_LOOP];
>> MPI_Init(&argc,&argv); /* Initialize MPI */
>> MPI_Comm_rank(MPI_COMM_WORLD, &rank); /* Get rank */
>> MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the LAM
>> universe */
>> if (size != 1)
>> printf("Error");
>> return -1;
>> //printf("CIAO\n");
>> MPI_Open_port (MPI_INFO_NULL,port_name);
>> printf("port_name= %s\n", port_name);
>> MPI_Publish_name("SERVER",MPI_INFO_NULL,port_name);
>> printf("waiting...\n");
>> while(1)
>> MPI_Comm_accept (port_name, MPI_INFO_NULL, 0,
>> MPI_COMM_WORLD, &client);
>> again=1;
>> while (again == 1)
>> printf("\nReceive\n");
>> MPI_Recv(buf,MAX_DATA,MPI_DOUBLE,MPI_ANY_SOURCE,MPI_ANY_TAG,
>> client, &status);
>> MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, 2, client);
>> printf("MPI_TAG =%d\n ", status.MPI_TAG);
>> switch(status.MPI_TAG)
>> case 0:
>> MPI_Comm_free(&client);
>> MPI_Close_port(port_name);
>> MPI_Finalize();
>> return 0;
>> case 1:
>> MPI_Comm_disconnect(&client);
>> again =0;
>> break;
>> case 2:
>> //for (i=0;i<MAX_DATA;i++)
>> printf("buf[%d]= %f",1,buf[1]);
>> //}//end for
>> break;
>> default:
>> MPI_Abort (MPI_COMM_WORLD,1);
>> break;
>> } //end of switch
>> } //end while again
>> } //infinity
>> // CLIENT
>> #include <stdio.h>
>> #include <mpi.h>
>> #include <sys/time.h>
>> #define LOOP 10000
>> int rank, size,i, tag=0, done=1;
>> MPI_Comm server;
>> MPI_Status status;
>> double var=0.0;
>> int time[LOOP];
>> struct timeval tv1, tv2;
>> FILE *fp;
>> long max=0, min=20000000;
>> //MPI_Comm_size(MPI_COMM_WORLD,&size); /* Get size of the
>> LAM universe */
>> MPI_Lookup_name("SERVER", MPI_INFO_NULL, port_name);
>> printf("\nMPI_Lookup_name Port_name= %s", port_name);
>> MPI_Comm_connect (port_name, MPI_INFO_NULL,0,
>> MPI_COMM_WORLD, &server);
>> buf[i]= i*2.0;
>> //printf("buf[%d]= %f\t",i,buf[i]);
>> tag=2;
>> for(i=0;i<LOOP;i++)
>> gettimeofday(&tv1, NULL);
>> MPI_Send(buf, MAX_DATA, MPI_DOUBLE, 0, tag, server);
>> server, &status);
>> gettimeofday(&tv2, NULL);
>> time[i]=(int)TIMER_ELAPSED;
>> printf("\nsend and receive con buf[%d]= %f\n",1,buf[1]);
>> printf("Client Tempo[%d]= %d\n",i, time[i]);
>> } //end for
>> tag=1;
>> printf("\nSend con tag 1\n");
>> MPI_Comm_disconnect(&server);
>> MPI_Finalize();
>> /* *************** TIME RESULTS ***************** */
>> fp= fopen("Results.txt","w");
>> for(i=0;i<LOOP;i++)
>> fprintf(fp,"%d %ld \n", i+1 ,time[i]);
>> var=var+time[i];
>> if(time[i]<min) min=time[i];
>> if(time[i]>max) max=time[i];
>> var=var/LOOP-1;
>> printf("Tempo del client %d = %f usec\n",rank,var);
>> fprintf(fp,"LATENCY TIME MIN = %ld microsec\n", min);
>> fprintf(fp,"LATENCY TIME MAX = %ld microsec\n", max);
>> fprintf(fp,"LATENCY TIME AVERAGE = %f microsec\n", var);
>> fclose (fp);
>> return 0;
>> Visita http://domini.interfree.it, il sito di Interfree dove trovare
>> soluzioni semplici e complete che soddisfano le tue esigenze
>> in Internet,
>> ecco due esempi di offerte:
>> - Registrazione Dominio: un dominio con 1 MB di spazio disco
>> + 2 caselle
>> email a soli 18,59 euro
>> - MioDominio: un dominio con 20 MB di spazio disco + 5 caselle email
>> a soli 51,13 euro
>> Vieni a trovarci!
>> Lo Staff di Interfree
soluzioni semplici e complete che soddisfano le tue esigenze in Internet,
- Registrazione Dominio: un dominio con 1 MB di spazio disco + 2 caselle
a soli 51,13 euro
Vieni a trovarci!
