[MPICH] test not working
    Mike Zupan
    hijinks at gmail.com
    Fri Aug 26 21:21:26 CDT 2005
i'm using linux. its fedora core3.. there are no firewalls in place i
have also done
hostname.domain.com user
in the .rhosts file with no luck.. i mean i can rsh in just not use mpirun
On 8/26/05, peter_raeth at juno.com <peter_raeth at juno.com> wrote:
> Since I am not able to tell from the console display, what operating system
> are you using?
> I'm having an issue getting our cluster working.. Here
> is what I get
> when i run mpirun on an example
> [wind at cluster1 basic]$ mpirun -np 2 cpilog
> connect to address 192.168.0.10: Connection refused
> Trying krb4 rsh...
> trying normal rsh (/usr/bin/rsh)
> It just halts there. I can rsh just fine from the
> master node to the other node
> [wind at cluster1 basic]$ rsh node1 date
> Trying krb4 rsh...
> Fri Aug 26 08:18:04 PDT 2005
> my /home dir is nfs mounted on node1
> here is the .rhosts file
> node0 wind
> node1 wind
> I'm out of ideas.. i've been reading for about 5 hours
> now with no luck
> any pointers?
> thanks
> mike
> http://www.zcentric.com/wiki
> My Linux Howto/Tips Wiki
