[MPICH2 Req #1798] [MPICH] Problem compiling mpich2-1.0.2p1 on FreeBSD 5.4
    Anthony Chan
    chan at mcs.anl.gov
    Wed Aug 10 14:47:20 CDT 2005
That is strange, your configure output(c.txt) does not contain any
configure output from MPE ?  As if MPE was not configured!
The failure in make was not related to clog2_print, make error occured
in building MPE's collective and datatype checking library.
FYI: I just configured/built/ran mpich2-1.0.2p1 on FreeBSD 5.3. with the
following configure options
~/mpich2_work/mpich2-1.0.2p1/configure
--prefix=/home/chan/mpich2_work/install_102p1 --disable-collchk
--disable-f77 --disable-f90 | & tee c.txt ; make | & tee m.txt ;
make install |& tee mi.txt
With these options, you still get the typical MPE logging....
features except the new collective/datatype checking library.  I
will look into why the new library fails to build on FreeBSD.
A.Chan
On Wed, 10 Aug 2005, Yann Golanski wrote:
> Quoth Anthony Chan on Wed, Aug 10, 2005 at 10:44:16 -0500
> > Can you send me the complete configure and make output, i.e. c.txt and
> > m.txt from the following commands ?
> Attached.
> Thanks.
> yann at kierun.org                  -=*=-                      www.kierun.org
>     PGP:   009D 7287 C4A7 FD4F 1680  06E4 F751 7006 9DE2 6318
