[MPICH] MPICH2 on WinXP-Pro cluster
    PETER RAETH
    PeterRaeth at email.uophx.edu
    Tue Aug  9 08:40:36 CDT 2005
David,
The script is exactly what I did with the earlier and latest version. The
latest version is what is now installed. However, when I tried it with the
earlier version the account mess was still in place.
What I think happened is that the account being wrongly set up by WinXP-Pro
(one name in some places, another name in others) is what caused the
problem.
The script did not work at all, with either version, until the account mess
was cleared up.
Also to be said is that I turned off the firewall and the anti-virus/worm
software during all attempts. That worked since there are no outside
connections when the system is operating as a network/cluster. As you said
earlier, the firewall can be told to allow specific users.
Best,
Peter.
Peter Raeth, Ph.D., Faculty
University of Phoenix (Online Campus)
http://www.geocities.com/peter_raeth/
----- Original Message -----
To: "'PETER RAETH'" <PeterRaeth at email.uophx.edu>
Cc: <mpich-discuss at mcs.anl.gov>
Sent: Monday, August 08, 2005 11:14 PM
Subject: RE: [MPICH] MPICH2 on WinXP-Pro cluster
> Peter,
> So did you try running your job like you mentioned in your previous email?
> "C:\PROGRA~1\MPICH2\bin>mpiexec -pwdfile Options.txt -exitcodes -hosts 2
> familycomputer raethserver cpi"
> Did this fail after installing the latest version but it worked with an
> older version?
> -David Ashton
