[Mochi-devel] Margo + sockets provider inexplicably slow
Phil Carns
carns at mcs.anl.gov
Thu Sep 2 08:15:35 CDT 2021
Hi Clément,
What benchmark are you using to generate these numbers?
My first guess would be a difference in polling strategy (how frequently
HG_Progress() is being called, and with what timeout value), and how
well the provider handles that.
One quick and dirty way to test this theory would be to set the
margo_init_info -> hg_init_info ->
na_init_info -> progress_mode to NA_NO_BLOCK before initializing margo
with margo_init_ext(). There is an example that does this here:
https://github.com/mochi-hpc-experiments/mochi-tests/blob/main/perf-regression/margo-p2p-latency.c#L105
That's tedious from an API perspective, but the reason it might be
informative as a quick hack is that it will force Mercury to busy poll
on the underlying transport no matter what margo or other callers are
actually asking it to do. It effectively short circuits any higher
level polling strategy decisions.
Depending on what that tells us, we can go from there. I suspect that
the sockets provider mechanism for waiting for events (as opposed to
just polling for events) might be problematic.
thanks,
-Phil
On 9/2/21 8:29 AM, Clement Barthelemy wrote:
> Hello all,
> I did some latency measurement to compare Mercury and Margo with different providers, the results are below:
> Mercury (s/RPC) Margo (s/RPC)
> ofi+psm2 6.21e-5 5.01e-5
> ofi+tcp;ofi_rxm 8.20e-5 9.55e-5
> ofi+sockets 7.54e-5 2.08e-2 (!)
> As you can see, the Margo + the sockets provider is 250 times slower than the rest. I first suspected libfabric, but Mercury does not have the problem. Do you know what could be causing this?
> I've tested with Margo 0.9.5, Mercury 2.0.1 and libfabric 1.12.1 & 1.13.1.
> Thanks,
> Clément
> mochi-devel mailing list
> mochi-devel at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/mochi-devel
> https://www.mcs.anl.gov/research/projects/mochi
URL: <http://lists.mcs.anl.gov/pipermail/mochi-devel/attachments/20210902/a54895d5/attachment.html>
More information about the mochi-devel
