[Mochi-devel] Example of running other work units in the same execution stream as margo
Dorier, Matthieu
mdorier at anl.gov
Tue Jul 28 11:13:50 CDT 2020
Hi Philip,
Are you trying to submit new ULTs from inside an RPC handler? Or have totally unrelated ULTs that just happen to be in the same ES as RPC handlers?
Matthieu
On 28/07/2020, 16:49, "mochi-devel on behalf of Philip Davis" <mochi-devel-bounces at lists.mcs.anl.gov on behalf of philip.e.davis at rutgers.edu> wrote:
Hello,
Is there an example somewhere of a program that runs other work units in the same execution stream as the rpc handler for margo? I am a bit shaky on argobots usage, so any pointers would be helpful.
Philip
mochi-devel mailing list
mochi-devel at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mochi-devel
https://www.mcs.anl.gov/research/projects/mochi
More information about the mochi-devel
