[Mochi-devel] running mochi examples
Latham, Robert J.
robl at mcs.anl.gov
Tue Nov 12 14:33:18 CST 2019
On Tue, 2019-11-12 at 13:42 +0000, Carns, Philip H. via mochi-devel
wrote:
> Hi Abid,
> It still sounds like your libfabric build does not include the verbs
> and rxm providers. If you want to confirm this, then load the
> libfabric package and (on a compute node, within a job script) run
> "fi_info" and save the output.
OH! Abid, are you running from the login nodes? that's not going to
work.
A more succint way to get the information Phil requested: 'fi_info -l'
will list the providers it knows:
Here's the output from the summit login node:
% fi_info -l
ofi_rxm:
version: 1.0
shm:
version: 1.1
ofi_perf_hook:
version: 1.0
ofi_noop_hook:
version: 1.0
ofi_mrail:
version: 1.0
Summit login node doesn't have any infiband cards, so it does not
advertise the infiniband (verbs) provider.
But how about from a compute node? Here's what I see:
% bsub -W 0:10 -nnodes 2 -P CSC332 -Is /bin/bash
Job <732804> is submitted to default queue <batch>.
<<Waiting for dispatch ...>>
<<Starting on batch1>>
robl at batch1:$ fi_info -l
verbs:
version: 1.0
ofi_rxm:
version: 1.0
shm:
version: 1.1
ofi_perf_hook:
version: 1.0
ofi_noop_hook:
version: 1.0
ofi_mrail:
version: 1.0
The rest of Phil's message is spot-on -- if you don't see 'verbs' from
the compute node, you'll have to rebuild libfabric.
==rob
More information about the mochi-devel
