[Mochi-devel] Mochi on Summit
    Dorier, Matthieu
    mdorier at anl.gov
    Fri Nov  1 08:34:38 CDT 2019
You can uninstall the version that was compiled with gcc 4.8 by doing
spack uninstall margo %gcc at 4.8.5
or
spack uninstall margo /t3x4fur
Make sure that spack uses gcc 6.4.0 by default since many of the Mochi libraries won’t compile with 4.8.
Matthieu
From: mochi-devel <mochi-devel-bounces at lists.mcs.anl.gov> on behalf of Abid Malik via mochi-devel <mochi-devel at lists.mcs.anl.gov>
Reply to: Abid Malik <abidmuslim at gmail.com>
Date: Friday, 1 November 2019 at 12:30
To: "mochi-devel at lists.mcs.anl.gov" <mochi-devel at lists.mcs.anl.gov>
Subject: [Mochi-devel] Mochi on Summit
Hello,
I am trying to play with Mochi on Summit. I installed it using Spack. It was successful. However, when I use spack load -r margo I got the following error:
[amalik at login5.summit mochi]$ spack load -r margo
==> Error: the constraint '['margo']' matches multiple packages:
t3x4fur margo at 0.5.2%gcc at 4.8.5 arch=linux-rhel7-power8le
gniufvt margo at 0.5.2%gcc at 6.4.0 arch=linux-rhel7-power9le
==> Error: In this context exactly **one** match is needed: please specify your constraints better.
I think it is confused by the availability of two compilers. How should I solve this issue?
Abid M. Malik
"I have learned silence from the talkative, toleration from the intolerant, and kindness from the unkind"---Gibran
"Success is not for the chosen few, but for the few who choose" --- John Maxwell
"Being a good person does not depend on your religion or status in life, your race or skin color, political views or culture. IT DEPENDS ON HOW GOOD YOU TREAT OTHERS"--- Abid
"The Universe is talking to us, and the language of the Universe is mathematics."----Abid
URL: <http://lists.mcs.anl.gov/pipermail/mochi-devel/attachments/20191101/2876441e/attachment.html>
More information about the mochi-devel
