[Mochi-devel] An overview of application usage scenarios
Carns, Philip H. carns at mcs.anl.gov
Mon Jul 8 12:32:03 CDT 2019
There are a few ways to go about it, but in this case I would probably do something like this:
spack install margo # install margo and its deps with spack
spack load -r margo # load resulting margo module and it's deps
spack unload margo # unload only margo (leaving dependencies loaded)
... then git clone margo, checkout branch, and configure/build
So basically just using spack to get all of the dependencies in place so the manual build of margo is easier.
thanks,
-Phil
From: Srinivasan Ramesh <sramesh at cs.uoregon.edu>
Sent: Monday, July 8, 2019 1:12 PM
To: Carns, Philip H.
Cc: mochi-devel at lists.mcs.anl.gov; Dorier, Matthieu
Subject: Re: [Mochi-devel] An overview of application usage scenarios
Hi Phil,
I needed some spack-related advice: Spack doesn't build these margo
examples by default, right? How do I instruct Spack to do so?
If not, what is the most efficient way to get the examples to build once
I have a margo spack installation in place?
Would you recommend that I build the breadcrumb repo separately, and
link to the spack-installed dependencies?
Any help would be much appreciated.
Srinivasan Ramesh
URL: <http://lists.mcs.anl.gov/pipermail/mochi-devel/attachments/20190708/e9d148fb/attachment.html>
More information about the mochi-devel mailing list
