[Mochi-devel] building against Merury origin/master, upcoming changes
Dorier, Matthieu mdorier at anl.gov
Tue Apr 3 05:52:33 CDT 2018
Hi all,
Update on Phil's mail: the corrections and improvement that he mentioned have been completed and merged. These corrections affect pretty much all of the Mochi libraries. We therefore encourage you to reinstall a clean build of all the libraries you are using.
If you are using spack, this can be done by updating your local copy of sds-repo (git pull). Then uninstall Mercury and all the libraries it depends on using the following command:
spack uninstall --dependents --all mercury
Finally you can reinstall the libraries you need (e.g. margo):
spack install margo
Matthieu
From: mochi-devel <mochi-devel-bounces at lists.mcs.anl.gov> on behalf of Phil Carns <carns at mcs.anl.gov>
Sent: Monday, March 26, 2018 3:29:42 PM
To: mochi-devel at lists.mcs.anl.gov
Subject: [Mochi-devel] building against Merury origin/master, upcoming changes
Hi all,
If you have tried to build Margo against Mercury's origin/master lately,
then you've already noticed that this doesn't work at the moment :)  The
short term fix is to use revision
6c82baf7819a553b6b8235fbe7c180989a1e17fe of Mercury, before the changes
landed that broke the Margo library.
We are working on a solution that will get origin/master of Margo and
Mercury back in sync, and also generally improve how Margo multiplexes
services.  This is actually one of 3 changes we are working on at the
moment to improve general maintenance and deployment of Margo (and thus
several other Mochi components):
1) see above, fix multiplexing in Margo and bring it back in sync with
Mercury
2) eliminate abt-snoozer dependency.  We are working on upstreaming the
capability we need in origin/master of Argobots if we can
3) eliminate boost dependency.  We are investigating the possibility of
embedding the subset of boost headers that Mercury needs into the
Mercury repo so that it no longer needs an external boost install
At any rate, the upshot is: Please pardon our dust, it will be better
soon, use an older revision of Mercury for now, and we'll let you know
when things are fixed!
thanks,
-Phil
mochi-devel mailing list
https://lists.mcs.anl.gov/mailman/listinfo/mochi-devel
https://www.mcs.anl.gov/research/projects/mochi
URL: <http://lists.mcs.anl.gov/pipermail/mochi-devel/attachments/20180403/1aba4abf/attachment.html>
More information about the mochi-devel mailing list
