[MOAB-dev] errors during make check
Charles Henkel csh at henktech.com
Sat Nov 8 01:38:29 CST 2025
Followup
I was working on the HEAD because "configure" was failing when I checked out tag 5.5.1. Turns out it was due to an (unmentioned) dependency on liblapack-dev.
When I installed liblapack-dev, the 5.5.1 version compiled and passed all tests.
Charles S. Henkel
Henkel Technical Computing, LLC
5816 N Saint Louis Ave
Loveland, CO  80538
Office (970)776-9735 Mobile (970)732-2159
Sent: Saturday, November 8, 2025 12:16 AM
To: moab-dev at mcs.anl.gov
Subject: errors during make check
Context
            Ubuntu 24.04 LTS virtual machine hosted in Hyper-V on Windows Server 2016
            Working on the head of the repo obtained by git clone https://urldefense.us/v3/__https://bitbucket.org/fathomteam/moab__;!!G_uCfscf7eWS!aWPxTREMKQiKyMRBFURKf_NOFufHgUDQ-RoRdpL7K8bfMKo5zr9TDlVtedQ8Nv9RDEvL9NiwWTD2EEHs$  (short hash 19bb18718)
Problem
            Failure during "make check" on vtk_test
            Contents of test/io/test-suite.log:
   MOAB 5.5.1: test/io/test-suite.log
# TOTAL: 11
# PASS:  10
# SKIP:  0
# XFAIL: 0
# FAIL:  1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
FAIL: vtk_test
*** buffer overflow detected ***: terminated
FAIL vtk_test (exit status: 139)
Potential Cause
            During "make all", these errors occurred several times:
      In file included from /usr/include/stdio.h:980,
                 from /usr/include/c++/13/cstdio:42,
                 from /usr/include/c++/13/ext/string_conversions.h:45,
                 from /usr/include/c++/13/bits/basic_string.h:4109,
                 from /usr/include/c++/13/string:54,
                 from ../../../src/src/moab/Range.hpp:166,
                 from ../../../src/src/moab/Interface.hpp:47,
                 from ../../../src/src/moab/Core.hpp:19,
                 from ../../../src/test/io/VtkTest.cpp:1:
In function 'int snprintf(char*, size_t, const char*, ...)',
    inlined from 'bool test_read_write_element(const double*, unsigned int, const int*, const int*, unsigned int, unsigned int, unsigned int, moab::EntityType)' at ../../../src/test/io/VtkTest.cpp:959:20:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:54:35: warning: 'int __builtin___snprintf_chk(char*, long unsigned int, int, long unsigned int, const char*, ...)' specified bound 4096 exceeds destination size 4019 [-Wstringop-overflow=]
   54 |   return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
   55 |                                    __glibc_objsize (__s), __fmt,
   56 |                                    __va_arg_pack ());
Charles S. Henkel
Loveland, CO  80538
