[MOAB-dev] Issue with DataCoupler
Andrei Shvarts Andrei.Shvarts at glasgow.ac.uk
Wed Mar 12 18:47:08 CDT 2025
Hello,
I am one of the core developers of MoFEM, for which MOAB is a backbone.
Recently, we have been looking for functionality to transfer data between meshes, and it appears that MOAB provides two options: Coupler and DataCoupler classes, the latter described as a more advanced version of the former.
As a starting point, we would need a constant projection from tags on elements in the source mesh to tags on elements in the target mesh. Coupler seems to handle this; however, we need to use 9-value tags (for stress tensors), while Coupler appears to support only scalar tags. We could store each stress component as a separate scalar tag and interpolate them individually, but this seems rather tedious, especially since the DataCoupler class appears to support multi-value tags.
However, I have been unable to transfer data from element tag to element tag using DataCoupler; the result is always zero. Even the datacoupler_test with the default meshes does not seem to work, as the resulting element tag values are all zero.
I ran the test with the following command:
./datacoupler_test -itag element_field -meth 0 -outfile out.h5m
I have compiled develop branch, commit f4c7a65af7cc9d520577877eeef39fd9e2493fde
Could you advise me please if I am using DataCoupler correctly?
Many thanks,
Kind regards,
Andrei
Dr Andrei Shvarts
Lecturer – Infrastructure & Environment
Glasgow Computational Engineering Centre
James Watt School of Engineering
University of Glasgow
