[MOAB-dev] PyMOAB
Vijay S. Mahadevan vijay.m at gmail.com
Thu Sep 23 13:45:59 CDT 2021
Thanks Paul. I apologize that I missed that. Yes you need to enable
PyMOAB since it is not configured by default.
Vijay
On Thu, Sep 23, 2021 at 2:32 PM Paul Wilson <paul.wilson at wisc.edu> wrote:
> Hi Kevin,
> You'll need to add the --enable-pymoab option in your configure line.
> Paul
> On 9/23/21 13:22, Kevin McLaughlin wrote:
> > Hi Paul,
> > Sure, I did
> > $ ../src/configure --enable-optimize \
> >                     --enable-shared \
> >                     --disable-debug \
> >                     --with-hdf5=/usr/lib/x86_64-linux-gnu/hdf5/serial \
> >                     --prefix=$HOME/dagmc_bld/MOAB \
> >                     --download-netcdf
> > Thanks!
> > Kevin McLaughlin
> > office: 858-455-3641
> > mclaughlink at fusion.gat.com
> > ----- Original Message -----
> > From: "Paul Wilson" <paul.wilson at wisc.edu>
> > To: "Kevin McLaughlin" <mclaughlink at fusion.gat.com>, "moab-dev" <moab-dev at mcs.anl.gov>
> > Sent: Thursday, September 23, 2021 11:15:41 AM
> > Subject: Re: [MOAB-dev] PyMOAB
> > Hi there,
> > Can you share how you built MOAB? either the 'configure' line or the
> > 'cmake' line?
> > Paul
> > On 9/23/21 13:13, Kevin McLaughlin wrote:
> >> Hello,
> >> I'm trying to use MOAB for some neutronics work, but I am running into a problem relating to PyMOAB. I built MOAB, and everything seems to be functioning, but I am unable to setup PyMOAB. PyMOAB isn't importable in python, and there is only a setup.py.in file, not a setup.py file. When I try to run setup.py.in, I get the error "No such file or directory: '@abs_builddir@/pymoab'". I'm sure this is some mistake on my part, but I can't figure this out. Could you advise on how I can get PyMOAB set up?
> >> Thank you!
> >> Kevin McLaughlin
> Paul P.H. Wilson (he/him/his)
> Grainger Professor of Nuclear Engineering
> Chair, Department of Engineering Physics <http://engr.wisc.edu/ep>
> o: 608-263-0807, c: 608-469-9615
> 153 Engineering Research Bldg
> 1500 Engineering Dr, Madison, WI 53706
> Zoom Meeting Room: https://uwmadison.zoom.us/j/6082630807
> Zoom Phone Access: +1-929-205-6099, Access code: 6082630807
> Computational Nuclear Engineering Research Group
> <http://cnerg.engr.wisc.edu>
