[MOAB-dev] Help for migration of cells between MPI subdomains with moab
Olivier Jamond
olivier.jamond at cea.fr
Mon Jun 14 02:38:43 CDT 2021
Hello Iulian,
I am not sure to understand perfectly what you mean: I feel that my
problem is not just about the tags for the parallel status, but I also
need to moves entities between processes in the first place. What I have
in mind, as you suggest, is that after migrating the entities between
processes, I would have to call 'resolve_shared_ents' to update the
parallel status tags (assuming that the vertices global ids have been
preserved during migration...). Does this make sense?
Yes, in the parts of the numerical model where a numerical method
involving stencils (such as finite-volumes) is used, the ghost layers
will have to be recomputed at least "around" the cells that have been
migrated.
Thanks a lot for helping!
Best regards,
Olivier
On 12/06/2021 02:37, Grindeanu, Iulian R. wrote:
> Hello Olivier,
> Now thinking more about your scenario, my suggestion is to recompute the parallel tags at every stage (rebalancing of the mesh)
> adding, resetting, updating the parallel tags is an error prone process; it would be better to start from a clean state at every rebalancing; even of you move just a few elements from some processes to others.
> Will you have to recompute ghost layers, etc ?
> Everything will happen in memory, and computing the parallel tags is done with "resolve shared entities" type methods, that happen after a parallel distributed read, for example, or when migrating a full mesh to a different set of processes.
> The parallel info is stored in many tags, some are sparse, some are dense, and setting and resetting those for a limited set of cells/vertices will not be much faster than just recomputing all
> It is important to keep global ids tags consistent on vertices, and on cells to keep track of them; partitions are cell-based partitions, and vertices and lower dim entities will be shared.
> we can discuss more
> Iulian
> From: Olivier Jamond <olivier.jamond at cea.fr>
> Sent: Friday, June 11, 2021 12:01 PM
> To: Vijay S. Mahadevan
> Cc: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Help for migration of cells between MPI subdomains with moab
>> We can read in MOAB mesh files using different approaches in parallel.
>> But my understanding is that you need to move entities that are
>> in-memory, right ?
> Yes exactly!
>> Understood. The iMOAB interface implementation that I mentioned
>> earlier is targeted at moving the entire mesh topology from one set of
>> processes to another. Not just a subset - though it very well could be
>> based on a provided list of entities or a meshset containing the
>> subset. You can look at iMOAB_SendMesh/iMOAB_ReceiveMesh [1] for an
>> implementation to send mesh pieces between processes. There may be
>> enough logic there that can be extracted and exposed through a new API
>> in ParallelComm if needed. Here is a sample routine [2] that sends the
>> local part of the mesh to a target process. These may not be directly
>> usable for your use-case without buying fully into the iMOAB
>> interface, but hopefully gives you an example to move forward.
>> Do let us know if you have further questions. We may have better
>> suggestions after looking at your example.
>> Vijay
>> [1] https://ftp.mcs.anl.gov/pub/fathom/moab-docs/iMOAB_8cpp_source.html
>> [2] https://ftp.mcs.anl.gov/pub/fathom/moab-docs/classmoab_1_1ParCommGraph.html#ae13a1f5915695ffd602274b635644125
> I will have a look at these two functions that I haven't spotted yet!
> Thanks again, we'll keep in touch!
> Olivier
>> On Fri, Jun 11, 2021 at 11:57 AM Olivier Jamond <olivier.jamond at cea.fr> wrote:
>>> Hi Vijay and Iulian,
>>> Thanks for your answers. I attach my simple toy code to this mail.
>>> Please tell me if you get it this time!
>>> I just looked at the iMesh interface. Do you carry out migration using
>>> the hdds with the write/load_mesh functions?
>>> In some of our cases, we plan to do quite 'high frequency' load
>>> balancing, mainly for fast transient explicit dynamic simulations. In
>>> this plan, we balance the mesh quite often (using Zoltan also), but at
>>> each rebalancing, the set of cells which have to be migrated is a small
>>> part of the cells involved in the calculation.
>>> We do not use the iMesh/ITAPS interface, so no problem with that! In
>>> fact we wrap in our 'Mesh' class a moab::Core instance and a
>>> moab::ParallelComm instance.
>>> Thanks a lot for your help,
>>> Best regards,
>>> Olivier
>>> On 11/06/2021 17:19, Vijay S. Mahadevan wrote:
>>>> Hi Olivier,
>>>> As Iulian mentioned, there is a lot of infrastructure written for our
>>>> Climate workflows to migrate a mesh from a process set A to a process
>>>> set B, where A and B can have overlaps or can be completely disjoint.
>>>> And during the process of migration, we can do repartitioning as well
>>>> since typically n(A) != n(B). Currently, this functionality is
>>>> available and heavily tested with iMOAB interface as it is consumed by
>>>> a Fortran90 based code. However, if you are interested in this for
>>>> arbitrary meshes, we can work with you to update that interface more
>>>> generally to support all dimensions. Note that this iMOAB migration
>>>> implementation currently works for all unstructured meshes on a sphere
>>>> (so the dimension is hard-coded in places).
>>>> I suggest you not use the iMesh/ITAPS framework as this is a legacy
>>>> interface and we are not too keen on supporting it going forward.
>>>> Thanks,
>>>> Vijay
>>>> On Fri, Jun 11, 2021 at 10:52 AM Grindeanu, Iulian R.
>>>> <iulian at mcs.anl.gov> wrote:
>>>>> Hello Olivier,
>>>>> Migration of meshes with ParallelComm methods is not a well tested piece of code, it is rather old;
>>>>> Your attachment did not go through, can you send it again to me directly?
>>>>> I would be happy to assist; In principle, the data needs to be packed, then sent/received using MPI , then unpacked;
>>>>> We do use the packing and unpacking quite extensively in currently tested code; we prefer now the migration of full meshes from a set of processes to another set, while repartitioning on the fly using Zoltan based methods (more exactly using iMOAB newer interface)
>>>>> I am pretty sure ParallelComm methods will work with minor fixes.
>>>>> We also support an iMesh / ITAPS based framework, which could assist in migration of elements, but that is just another layer / API ; the heavy duty work is still performed by ParallelComm
>>>>> Thanks,
>>>>> Iulian
>>>>> From: moab-dev <moab-dev-bounces at mcs.anl.gov> on behalf of Olivier Jamond <olivier.jamond at cea.fr>
>>>>> Sent: Thursday, June 10, 2021 7:32 AM
>>>>> To: moab-dev at mcs.anl.gov
>>>>> Subject: [MOAB-dev] Help for migration of cells between MPI subdomains with moab
>>>>> Dear Moab developers,
>>>>> I am working for the french CEA
>>>>> (https://en.wikipedia.org/wiki/French_Alternative_Energies_and_Atomic_Energy_Commission)
>>>>> on the development of a new software dedicated to HPC simulations of
>>>>> various mechanical scenarii (structures, fluid, FSI, other couplings,
>>>>> ...) using mesh-based methods (finite-elements, finite-volumes,
>>>>> hybrid-discontinuous-galerkin, ...).
>>>>> This new code uses moab to manage the topological connections between
>>>>> geometrical entities in a distributed memory context.
>>>>> For several reasons, especially for dynamic load balancing, we will need
>>>>> to be able to migrate cells between MPI processes during calculations.
>>>>> But at this time I am quite stuck with this with moab... So I wonder if
>>>>> maybe you could help me with that...
>>>>> I struggled for some time with the moab::ParallelComm class to try to
>>>>> migrate a cell from a process to another one, but without success. I
>>>>> attached to this email a very simple toy piece of code which illustrates
>>>>> that. In this simple program, I construct a basic mesh with 2 quads on
>>>>> the proc0, and I would like to migrate one of these quads to proc1, and
>>>>> then migrate it back to proc0. As I wrote in some comments in this code,
>>>>> I tried using different functions ('high-level' send/recv_entities,
>>>>> send_recv_entities, 'low-level' pack/unpack_entities), but without
>>>>> success yet...
>>>>> I would really appreciate if you could help me with that and maybe take
>>>>> a look at the attached simple code.
>>>>> Best regards,
>>>>> Olivier Jamond
