[MOAB-dev] Help for migration of cells between MPI subdomains with moab
Olivier Jamond
olivier.jamond at cea.fr
Fri Jun 11 12:01:35 CDT 2021
> We can read in MOAB mesh files using different approaches in parallel.
> But my understanding is that you need to move entities that are
> in-memory, right ?
Yes exactly!
> Understood. The iMOAB interface implementation that I mentioned
> earlier is targeted at moving the entire mesh topology from one set of
> processes to another. Not just a subset - though it very well could be
> based on a provided list of entities or a meshset containing the
> subset. You can look at iMOAB_SendMesh/iMOAB_ReceiveMesh [1] for an
> implementation to send mesh pieces between processes. There may be
> enough logic there that can be extracted and exposed through a new API
> in ParallelComm if needed. Here is a sample routine [2] that sends the
> local part of the mesh to a target process. These may not be directly
> usable for your use-case without buying fully into the iMOAB
> interface, but hopefully gives you an example to move forward.
> Do let us know if you have further questions. We may have better
> suggestions after looking at your example.
> Vijay
> [1] https://ftp.mcs.anl.gov/pub/fathom/moab-docs/iMOAB_8cpp_source.html
> [2] https://ftp.mcs.anl.gov/pub/fathom/moab-docs/classmoab_1_1ParCommGraph.html#ae13a1f5915695ffd602274b635644125
I will have a look at these two functions that I haven't spotted yet!
Thanks again, we'll keep in touch!
Olivier
> On Fri, Jun 11, 2021 at 11:57 AM Olivier Jamond <olivier.jamond at cea.fr> wrote:
>> Hi Vijay and Iulian,
>> Thanks for your answers. I attach my simple toy code to this mail.
>> Please tell me if you get it this time!
>> I just looked at the iMesh interface. Do you carry out migration using
>> the hdds with the write/load_mesh functions?
>> In some of our cases, we plan to do quite 'high frequency' load
>> balancing, mainly for fast transient explicit dynamic simulations. In
>> this plan, we balance the mesh quite often (using Zoltan also), but at
>> each rebalancing, the set of cells which have to be migrated is a small
>> part of the cells involved in the calculation.
>> We do not use the iMesh/ITAPS interface, so no problem with that! In
>> fact we wrap in our 'Mesh' class a moab::Core instance and a
>> moab::ParallelComm instance.
>> Thanks a lot for your help,
>> Best regards,
>> Olivier
>> On 11/06/2021 17:19, Vijay S. Mahadevan wrote:
>>> Hi Olivier,
>>> As Iulian mentioned, there is a lot of infrastructure written for our
>>> Climate workflows to migrate a mesh from a process set A to a process
>>> set B, where A and B can have overlaps or can be completely disjoint.
>>> And during the process of migration, we can do repartitioning as well
>>> since typically n(A) != n(B). Currently, this functionality is
>>> available and heavily tested with iMOAB interface as it is consumed by
>>> a Fortran90 based code. However, if you are interested in this for
>>> arbitrary meshes, we can work with you to update that interface more
>>> generally to support all dimensions. Note that this iMOAB migration
>>> implementation currently works for all unstructured meshes on a sphere
>>> (so the dimension is hard-coded in places).
>>> I suggest you not use the iMesh/ITAPS framework as this is a legacy
>>> interface and we are not too keen on supporting it going forward.
>>> Thanks,
>>> Vijay
>>> On Fri, Jun 11, 2021 at 10:52 AM Grindeanu, Iulian R.
>>> <iulian at mcs.anl.gov> wrote:
>>>> Hello Olivier,
>>>> Migration of meshes with ParallelComm methods is not a well tested piece of code, it is rather old;
>>>> Your attachment did not go through, can you send it again to me directly?
>>>> I would be happy to assist; In principle, the data needs to be packed, then sent/received using MPI , then unpacked;
>>>> We do use the packing and unpacking quite extensively in currently tested code; we prefer now the migration of full meshes from a set of processes to another set, while repartitioning on the fly using Zoltan based methods (more exactly using iMOAB newer interface)
>>>> I am pretty sure ParallelComm methods will work with minor fixes.
>>>> We also support an iMesh / ITAPS based framework, which could assist in migration of elements, but that is just another layer / API ; the heavy duty work is still performed by ParallelComm
>>>> Thanks,
>>>> Iulian
>>>> ________________________________________
>>>> From: moab-dev <moab-dev-bounces at mcs.anl.gov> on behalf of Olivier Jamond <olivier.jamond at cea.fr>
>>>> Sent: Thursday, June 10, 2021 7:32 AM
>>>> To: moab-dev at mcs.anl.gov
>>>> Subject: [MOAB-dev] Help for migration of cells between MPI subdomains with moab
>>>> Dear Moab developers,
>>>> I am working for the french CEA
>>>> (https://en.wikipedia.org/wiki/French_Alternative_Energies_and_Atomic_Energy_Commission)
>>>> on the development of a new software dedicated to HPC simulations of
>>>> various mechanical scenarii (structures, fluid, FSI, other couplings,
>>>> ...) using mesh-based methods (finite-elements, finite-volumes,
>>>> hybrid-discontinuous-galerkin, ...).
>>>> This new code uses moab to manage the topological connections between
>>>> geometrical entities in a distributed memory context.
>>>> For several reasons, especially for dynamic load balancing, we will need
>>>> to be able to migrate cells between MPI processes during calculations.
>>>> But at this time I am quite stuck with this with moab... So I wonder if
>>>> maybe you could help me with that...
>>>> I struggled for some time with the moab::ParallelComm class to try to
>>>> migrate a cell from a process to another one, but without success. I
>>>> attached to this email a very simple toy piece of code which illustrates
>>>> that. In this simple program, I construct a basic mesh with 2 quads on
>>>> the proc0, and I would like to migrate one of these quads to proc1, and
>>>> then migrate it back to proc0. As I wrote in some comments in this code,
>>>> I tried using different functions ('high-level' send/recv_entities,
>>>> send_recv_entities, 'low-level' pack/unpack_entities), but without
>>>> success yet...
>>>> I would really appreciate if you could help me with that and maybe take
>>>> a look at the attached simple code.
>>>> Best regards,
>>>> Olivier Jamond
