[MOAB-dev] Is 'make check' supposed to work?
Vijay S. Mahadevan
vijay.m at gmail.com
Fri Nov 6 17:04:01 CST 2020
Tim, No, that doesn't sound right. We have buildbot tests running nightly
just fine. Are you sure configuration is correct? You can send us the
config.log and we can take a look at it to see if something looks off. Also
do send details about the release or git hash as well so that we can try to
replicate if there is an issue.
Vijay
On Fri., Nov. 6, 2020, 16:04 Timothy Tautges, <ttautges at simscale.com> wrote:
> I'm compiling moab with netcdf and hdf5, and make check hs 32 tests passing
> and 20 failing. Is this expected?
> - tim
