[MOAB-dev] [MCS Sites] "brew install moab" not working
Jain, Rajeev jain at mcs.anl.gov
Tue Oct 22 12:14:11 CDT 2019
Will check and revert. Thanks for the update Alex.
Rajeev
Sent: Tuesday, October 22, 2019 10:36 AM
To: Alex Hackett; Jain, Rajeev
Cc: moab-dev at mcs.anl.gov
Subject: Re: [MCS Sites] "brew install moab" not working
I'm ccing Rajeev Jain who maintains the Homebrew build for MOAB.
Rajeev, please update [1] with more instructions to pull and build MOAB 5.1.0 with Homebrew. And looks like the current brew formula is pulling 5.0.0 still. Update this to 5.1.0 as well.
Alex, which version of OSX are you current using ? MOAB is part of the homebrew-science tap. So first run `brew tap brewsci/science` before executing `brew install moab`. Let me know if that helps.
Vijay
[1] https://press3.mcs.anl.gov/sigma/moab/installing-moab-via-homebrew/
[2] https://github.com/brewsci/homebrew-science/blob/master/Formula/moab.rb
On 10/22/19, 10:24 AM, "Alex Hackett" <hackettac at ornl.gov> wrote:
    The "brew install moab” commend is not working on my in my Mac terminal. Error messages shown below.
    Alex
    mac96416:~ ***$ brew install moab
    Error: No available formula with the name "moab"
    ==> Searching for a previously deleted formula (in the last month)...
    Error: No previously deleted formula found.
    ==> Searching for similarly named formulae...
    Error: No similarly named formulae found.
    ==> Searching taps...
    ==> Searching taps on GitHub...
    Error: No formulae found in taps.
