[MOAB-dev] [MCS Sites] Issue about building MOAB 5.1.0
Mahadevan, Vijay S.
mahadevan at anl.gov
Tue Oct 22 10:31:40 CDT 2019
Can you send us your config.log file ?
> Althought I've download BLAS3.8.0 which I've specified in the cmd line "--with-blas=/path/to/BLAS3.8.0" , the traceback tells that "checking for sgemm_ in /home/feng/BLAS-3.8.0/... no".
The configure option --with-blas expects the path to the actual BLAS library file and not just the directory. Can you retry this by specifying the exact file path with MOAB 5.1.0 ?
I would suggest using MOAB 5.0 or above unless there is a strong reason to not do so. This would make things easier for us to help you with any usage or build/configuration issues.
Vijay
On 10/17/19, 2:15 AM, "Lingfeng WEI" <dimitri.wei.lingfeng at gmail.com> wrote:
Mr/Mrs,
When I build the pkg following your guide until ./configure step,
my cmd line is "./configure --enable-optimize --enable-shared --disable-debug --with-hdf5=/usr/lib/x86_64-linux-gnu/hdf5/serial --prefix=$HOME/dagmc_bld/MOAB",
Error occurs:
"checking for sgemm_ in ... no
checking if sgemm_ is being linked in already... no
checking for sgemm_ and dgemm_ in -latlas... no
checking for sgemm_ and dgemm_ in PhiPACK libraries... no
checking for sgemm_ in -lmkl... no
checking for sgemm_ in -lcxml... no
checking for sgemm_ in -ldxml... no
checking for sgemm_ in -lscs... no
checking for sgemm_ in -lcomplib.sgimath... no
checking for sgemm_ in -lblas... no
configure: error: BLAS library not found"
I've tried also Version5.0.0, but it does not work. As I tried older version4.6.3, it comes to another problem:
"ReadABAQUS.cpp: In destructor ‘virtual moab::ReadABAQUS::~ReadABAQUS()’: ReadABAQUS.cpp:108:12: error: no match for ‘operator!=’ (operand types are ‘long int’ and ‘std::ifstream {aka std::basic_ifstream}’) if (NULL != abFile)"
I really want to use moab, and I have try every solutions which did not work at all. Therefore, I have no idea how to fix this problem now.
Please help me!
Sincerely!
Lingfeng WEi.
