[MOAB-dev] parallel write and restart with variable length tags
Lukasz Kaczmarczyk
Lukasz.Kaczmarczyk at glasgow.ac.uk
Mon Dec 3 16:15:43 CST 2018
Hello,
I have this error for parallel when I write, then read in parallel, could you advise how to fix this error,
[1]MOAB ERROR: --------------------- Error Message ------------------------------------
[1]MOAB ERROR: Unordered file ids for variable length tag not supported!
[1]MOAB ERROR: read_var_len_tag() line 3335 in src/io/ReadHDF5.cpp
[1]MOAB ERROR: ReadHDF5 Failure!
[1]MOAB ERROR: read_tag() line 2769 in src/io/ReadHDF5.cpp
[1]MOAB ERROR: load_file_partial() line 1164 in src/io/ReadHDF5.cpp
Kind regards,
Lukasz
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20181203/30728011/attachment-0001.html>
Desc: restart_1.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20181203/30728011/attachment-0001.obj>
