[MOAB-dev] get_adjacencies after exchange_ghost_cells
Ryan O'Kuinghttons ryan.okuinghttons at noaa.gov
Mon Nov 19 16:29:28 CST 2018
you should probably rebuild everything, just in case..
i just pushed another small mod to turn off some internal debugging
code, so pull and then rebuild, and don't forget to 'make distclean'
before rebuilding!
On 11/19/18 15:25, Grindeanu, Iulian R. wrote:
> sorry,
> I just got to it;
> do I have to recompile everything?
> I had a small compile error, probably you fixed it in the new version
>       Range elems;
> -    merr=mb->get_entities_by_dimension(0, mbmp->pdim, elems);
> +    merr=moab_mesh->get_entities_by_dimension(0, mbmp->pdim, elems);
>       MBMESH_CHECK_ERR(merr, localrc);
> so can I recompile just moab part?
> Iulian
> From: Ryan O'Kuinghttons <ryan.okuinghttons at noaa.gov>
> Sent: Monday, November 19, 2018 4:21:31 PM
> To: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: get_adjacencies after exchange_ghost_cells
> Hi Iulian,
> After some more debugging, the issue seems to be an old one.. the
> elem_coords tag is not coming across on the ghost elements. I am using
> separate exchange_tags calls as you instructed:
>     Range nodes;
>     merr=mbmesh->mesh->get_entities_by_dimension(0, 0, nodes);
>     merr = pcomm->exchange_tags(node_tags, node_tags, nodes);
>     Range elems;
>     merr=mbmesh->mesh->get_entities_by_dimension(0, mbmesh->pdim, elems);
>     merr = pcomm->exchange_tags(elem_tags, elem_tags, elems);
> Also, I resolved the issue with double call to resolve_shared_ents..
> This version:
>     pcomm->resolve_shared_ents(0, mbmp->pdim, mbmp->pdim-1);
> is what was being used in MBMesh_addelements, and it doesn't seem to do
> the job. When I replaced it with this version it worked:
>     mbmp->mesh->get_entities_by_dimension(0, mbmp->pdim, elems);
>     pcomm->resolve_shared_ents(0, elems, mbmp->pdim, mbmp->pdim-1);
> I pushed this change to the moab4 branch along with some other debugging
> code.
> Ryan
> On 11/19/18 12:53, Ryan O'Kuinghttons wrote:
>> Hi Iulian, I'm seeing an issue with calling get_adjacencies after the
>> exchange_ghost_cells/tag_exchange call. For some reason, the Range of
>> adjacencies contains elements without tags. Is there something special
>> that needs to be done in this case?
>> Also, I am still calling resolve_shared_ents twice, once in
>> MBMesh_addelements and then again in the ghost exchange routine,
>> because without that second call the adjacencies don't seem to include
>> ghosted elements at all..
>> The reproducer is updated on the moab4 branch if you want to try it
>> again:
>> esmf/src/Infrastructure/Mesh/tests/ESMC_MeshMOABGhostUTest.C
